opinions on my DIY bag brackets
Well I finished my AOL bag brackets and was looking for any feedback if it looks OK to install.Is 3/16 with 1/8 side struts welded by a shop.Was thinking of going over the top piece with my 110 wirefeed where is wasn,t welded.Thats why I asked in other thread [A welding ?] if was OK to weld beside another weld
meowMEOWmeowMEOW
Re: opinions on my DIY bag brackets
While I don't have the most favorable opinion of air-over-leaf, I'll keep it to your question.
If it were me, I'd throw a stitch of weld on all the sides where none was put. IMO 1.5" long stitches about the same apart would be my choice. There is nothing wrong with welding on the other side of where the first welds are, just keep your heat under control, since everything is already squared up. I don't know about the rest of your setup, just make sure that at FULL compression (under some weight) the girth of your bag doesn't rub or touch the walls of the bracket. I had cups that came close and eventually rubbed, causing a near blowout.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Yeah i would weld it on the other side too,I have a bad habit of over building stuff but i have never worried if something will break or had anything break on me tho.
I too have a bad habit of over building,I,m not surprized I didn,t make it out of 1/2 inch steel
#5 | |
Happy to be here
![]() Join Date: Mar 2000
I agree, add a stitch or two for piece of mind. No, it probably won't help in the least bit but you will feel better.
As for the negative vibe about AoL, get past it. They work just fine, if set of properly. I have a few years and miles on one to verify that there is nothing bad about an AoL system.
meowMEOWmeowMEOW
I said I wasn't gonna get into it....but...Its not that they don't work...its just that its a half-measure for certain vehicles where the ease of 3 or 4link exists. (im gonna hate on 2 links and parrallel 4's, but thats just stigma left over from my mini trucking days).
I won't stop anyone from doing it, and heck there are some cars where I wouldn't argue especially for same of room/clearance. In a truck there is SO much room and its all easy to get it. I've had and driven them as well; the lack of additional moving parts and specialized aftermarket pieces for the install usually means that they are mostly maintenance free. My issue with them is that either your overall travel is limited. You can't lift nearly as far, and to lay fully out you usually have to lose multiple leaf springs, depending on the weight of the bed. And it isn't as much fun for side-to-side if you play with switches alot.
