Old 07-24-2012, 04:54 PM   #1
Rusty Wrenches
Rusty Wrenches's Avatar
Carb ID help Chevy 250
All i know aboutthis carb is its a single barrel with choke that has a sticker on the side that says remanufactured. Other than that can anyone help me identify what I've got so I can get this thing rebuilt. Thanks.
Rusty Wrenches is offline   Reply With Quote
Old 07-24-2012, 05:07 PM   #2
1963c-10
1963c-10's Avatar
Re: Carb ID help Chevy 250
Rochester model B.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-24-2012, 05:22 PM   #3
Rusty Wrenches
So is that a BC then because its got a choke ?
Old 07-24-2012, 10:43 PM   #4
Wrenchbender Ret
It is a Rochester model B. The Monojet came out in 68. The designation BC was for automatic choke. There should be a tag under one of the air horn screws but its probably long gone by now. There is only one kit for the 61 or 62 models on up, so you should be able to get the kit by aplication.
Wrenchbender Ret is offline   Reply With Quote
Old 07-24-2012, 10:50 PM   #5
Rusty Wrenches
Thanks for the help. I think I've located the right kit. This thing needs to rebuild pretty bad, drinks as much fuel as it pisses.
Old 07-25-2012, 08:04 AM   #6
1963c-10
1963c-10's Avatar
They are pretty easy to rebuild...only around 40 parts give or take a few. It is a 63-67 carb by the appearance and the fast idle adjust screw on the top where the choke is on the carb. The earlier model B didnt have this.
