07-24-2012, 04:58 PM | #1 |
V6 VS V8 frame pads HELP!
I want to put a small block V8 into a project truck I have but it looks like the truck may have come with a V6 from the factory. Is there a difference between the frame to motor mount with a V6 vs. a V8 on a 1985-86 C10? I picked up a set of 1985 C10 350 motor mounts and no way they will fit to the frame mounts. I bought the frame bare and shortened it to fit under my 1958 Apache. I want to test fit the engine before I go any farther. I have been looking all over for pictures or info and can’t find anything. I hope I can just replace the frame –motor mount pads and move ahead.
Thanks Steve Picture of driver side frame pad and the new motor mount NO GO! or am I missing something? |
07-24-2012, 08:41 PM | #2 |
Re: V6 VS V8 frame pads HELP!
It looks like it is different. Just snapped this pic off my 78 c10 which had an INLINE 6 in this case it's just a matter of slipping the motor mount to the upper holes on that plate. It doesn't look the same as yours
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
07-24-2012, 09:14 PM | #3 |
Looks like the wrong plate to me, and its mounted to far back also. Go get a set from your local junkyard.
John 82 Chevy Silverado 350ci/TH350 |
07-24-2012, 09:45 PM | #4 |
Here is the pass side totaly different then the drivers side. Looks like I am going to the junk yard. Thanks
