07-24-2012, 07:32 PM | #1 |
Factory tire size
I recently acquired a 1970 C10 and the speedo is off by about 30%. I think this is in part to the tires being too large.
The truck is a factory 307 w/3 on the tree. What would the factory tire size and rear end have been? Posted via Mobile Device |
07-25-2012, 12:16 AM | #2 |
Re: Factory tire size
G-78-15 is the factory size.I think that comes out to 215-75-15. I'm probably wrong but its close.I forget what ratio but I think mine had 3:73.
I'm running 255-70-15 on mine now and it is running 3 mph faster than speedometer. |
07-25-2012, 12:52 AM | #3 |
Welcome to the board!
The G78-15B tires and 3.73 rear ratio were standard for your truck. That translates to about a 28" dia. tire. Here is a tire chart link as well. http://www.tirerack.com/tires/tirete...sionchart.html
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-25-2012, 01:11 AM | #4 |
Hey clemsonteg ...
to the forums and from Ohio. By the way we luv pics
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-25-2012, 10:57 PM | #5 |
Thanks for the info! Currently the tires are 31x10.50x15 so that would make the speedo off by 5 mph at 40 mph. When my speedo says 40 I'm actually going about 55. Guess I need to check that rear end ratio. Sounds like its been changed over the years
Here's a pic. It's a solid 30 foot truck. Some rust and needs some work, but it runs and drives which is what I wanted to start with Posted via Mobile Device |
