Old 07-24-2012, 09:12 PM   #1
cstm68
cstm68's Avatar
ticking noise from 01 z71
a few weeks or so ago my 01 silverado with a 5.3l started to make a weird ticking noise, it only does it at speeds above 50 or so and i can only here it when passing a wall or concrete barrier on the freeway with the window down. rpm does not seem to change the noise but speed does. has anyone had this problem. i dont think its the motor but worried it could be from the tranny, its got aboyt 125k on it.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 07-26-2012, 12:38 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: ticking noise from 01 z71
Look at the exhaust manifolds, especially on the driver's side, and look for a missing bolt head. The one at the back by the firewall is notorious for snapping off on these trucks.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-27-2012, 07:17 PM   #3
bwood
bwood's Avatar
Check the ujoints.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 07-30-2012, 03:38 PM   #4
TowwDogg
TowwDogg's Avatar
Originally Posted by bwood View Post
Check the ujoints.
That sounds like a U joint to me too. When my U joint went out it was making a ticking noise.
TowwDogg is offline   Reply With Quote
Old 07-31-2012, 01:34 AM   #5
cstm68
cstm68's Avatar
sweet thanks! ill throw it on the lift tomorow and check all that!
Old 08-02-2012, 09:19 PM   #6
cstm68
cstm68's Avatar
checked my u joints and they are in good shape, i heard the noise again today and put the truck in N and didnt change it, it almost sounds like there is a rock in the tire but i only here it at freeway speeds and ony after its been at that speed for a few miles.
Old 08-05-2012, 05:57 PM   #7
gregory5000
I had a car do that one time and it was a trim ring on the rim.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 08-12-2012, 08:30 PM   #8
cstm68
cstm68's Avatar
could my u joints be bad but not have movement?
Old 08-15-2012, 02:05 AM   #9
cstm68
cstm68's Avatar
i replaced the u joints today and there was no change, i was able to get up to speed to make the noise and put the truck in neutral and shut shut the engine off and it still made the noise, does any one have any other ideas???
Old 08-15-2012, 08:53 AM   #10
truckdude239
truckdude239's Avatar
is it 4x4? the transer case could be going bad
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-15-2012, 07:59 PM   #11
clinebarger
Also check for missing brake hardware...A loose pad can cause clicking noises.
clinebarger is offline   Reply With Quote
Old 08-16-2012, 12:58 PM   #12
cstm68
cstm68's Avatar
yes its a 4x4, iv checked all the brake hardware and its all good.
i guess ill take it to my tranny guy and have him look at the t case
Old 09-08-2012, 01:54 AM   #13
cstm68
cstm68's Avatar
i got the truck up on the rack today and ran it to about 60mph in the air, i heard the noise and was able to track it to the t-case, i changed the fluid and that seemed to quiet it down but it is still there, would you guys reccomend having the transfer case rebuilt or just buy a new one?
Old 09-08-2012, 08:32 PM   #14
clinebarger
Because your catching it before complete meltdown....Have it rebuilt, These guys build all my manual transmissions & transfer cases.... http://www.standardtransmission.com/transfercases.html
Buying a NEW unit is Very expensive or impossible, Depending if you transfer case is still in production.
Old 09-11-2012, 10:23 PM   #15
cstm68
cstm68's Avatar
Took the t-case out today and to the tranny shop. He tore it apart and says that everything is fine. No loose chain or anything... Now I'm really stumped.
