07-24-2012, 11:30 PM | #1 |
rear disc?
The search button seams to be broke so I figured I would ask...
I am putting rear disc on my 76 stepper, I have the brackets to install the camaro calipers on the impala discs. I have a new master cylinder from the right stuff that is a replacement, but is supposed to work with disc??? My guy told me that I don't need a new disc/disc proportioning valve, that I can run my stock one, and just put an inline pressure regulator between it and the rear? So I get it all together, adjustable valve opened rite up, bench bleed master, but I can't bleed out rear, I have fluid at rear, but not getting any pressure, it seams to build up a bit on the first bleed, but after you pump it up again fluid just dribbles out, fronts bleed great... what are others doing on there conversions? thanks bark |
07-25-2012, 12:13 AM | #2 |
Re: rear disc?
I just use the oem lines with no adjustable valve and had no problems. Have plenty of pressure for bleeding and rear doesn't lock up before front.
1949 Five Window, 1973 Step Side, 2000 Z71 |
