Which is the best 12 bolt posi unit?
Is the Eaton the best? Or is something else as good or better? This is going on a frequently abused BB truck with slicks occasionally. Thanks!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Which is the best 12 bolt posi unit?
anyone?
I do know Auburn's aren't as easily rebuilt, whereas an Eaton you can rebuild quite easily and there's tons of different clutches and springs for them.
I was wondering what the 4x4 guys are doing? Surely a set of 44's in the mud and rocks is every bit as hard or harder on a posi than throwing huge torque through one on asphalt. Or do those guys go with Danas or 14 bolts? I THINK I have heard not as positive things about Auburn but I cannot recall and even searching the web have not had much luck finding real world experience.
![]() Join Date: May 2011
The off roaders use allot of Dana 60s and Corporate 14s and they seem to like the ARB air lockers because they know when they flip the switch it is on and don’t have to worry about it. Someone also makes a cable controlled posi that is getting popular as well, but I don’t remember who makes it. 4x4 posi units are all about the driver turning it on or off in the cab and having that control.
I ended up going with a detroit locker in my 12 bolt. Little pricey but its supposed to be able to take some abuse. Alot of BBC guys on this site pointed me towards the locker as well.
I went with the Eaton because it is quieter, I was told the Detroit makes a slite ratchet sound when driving but are tough as nails! good choice!
#8 | |
![]() Join Date: May 2007
I have had good luck with auburn lockers.... they have taken everything I have dished out!
Look up wave lock its the best out there currently. The eaton posi is good same as the detroit locker and true track. I have a true track myself. Stay away from auburns. They cant be rebuilt and wear out
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Well I bought a used Eaton from Leddzepp on here so I guess we will see how it holds up to the big block!
I went with an Auburn unit and it has been there for almost two years. It has hel really good with my small block 400 built.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#13 |
Does anyone make a Posi for 33 spline Moser axels GM 12 bolt? I currently have a spool but its not so cool on the street. Yes I said 33 spline
#14 |
I love my Eaton...never know its there til you need both wheels to pull. Every Auburn I have been around is pulling one wheel after a couple years.
70 Chevy Custom 10 400SB, Tremec TKO600, 3.73 posi. LWB hope to chop frame and have it short soon! 71 GMC LWB in the works of getting going for the first time since 1996 |
#15 |
![]() Join Date: Mar 2010
I have a pro series eaton in my 69, I used spools in my last few street/strip cars. I have not had much luck out of auburns, they tend to not like sticky tires and vht.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
