Old 07-25-2012, 10:46 AM   #1
19seventeeCustom
Radiator overflow
Hey guys,
I'm plumbing my coolant setup on my ls1 swap, and
was wondering what everybody is doing for a overflow setup?
I'm using my stock radiator, can I just run the overflow hose
to a overflow tank?
thanks
19seventeeCustom is offline   Reply With Quote
Old 07-25-2012, 11:10 AM   #2
Firebirdjones
Re: Radiator overflow
Yep, you can put anything in there you wish.
I just left my overflow hose open on my LS swap as that's how GM built the truck anyway.
Firebirdjones is offline   Reply With Quote
Old 07-25-2012, 11:13 AM   #3
19seventeeCustom
okay. that sounds great. thanks
i may just leave mine open also, any issues at all with this setup?
Old 07-25-2012, 11:27 AM   #4
Firebirdjones
No issues for the overflow, millions of cars made that way.
Environmentalists may not like though If you fill the radiator to the very top,,, It will drip (usually after you shut it down) and basically level itself off to a point where it stops doing it. And you are good to go.
An overflow however isn't a bad idea and having a closed cooling system can have some advantages. There are many aftermarket and factory style tanks that should fit your taste.
A neat way to do the 67-72 trucks (and I've been thinking about doing it myself) is to take another washer bottle and bracket that is used for the washer/wiper system and mount one on the other fender (passenger side) for an overflow. You just have to change the cap to a dual nipple design. One for the radiator hose and the other is your drain or vent.
Doing it this way on a 67-72 truck makes it appear like it's a factory setup...
Old 07-25-2012, 11:35 AM   #5
19seventeeCustom
awesome.
thanks so much for the help
Old 07-25-2012, 01:49 PM   #6
ls1nova71
ls1nova71's Avatar
If you run an open system, whatever you do, don't put Dexcool in it. When it mixes with air it turns to mud. Personally I never use it though, its crap in my book.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-25-2012, 04:23 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^this. Dexcool was a bad try at an environmentally friendly coolant....great until it turns to algea in your tank.
Get the green regular, or the Pink Universal....or you can be gangster like me and just run water and water wetter.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-26-2012, 08:46 AM   #8
Shon
I have my overflow into a old brake fluid bottle...stays empty!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-26-2012, 09:53 AM   #9
softballnrd27
Always a work in progress
softballnrd27's Avatar
I used to use and old crown royal bottle with a hole in the lid!!
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-26-2012, 12:20 PM   #10
ls1nova71
ls1nova71's Avatar
My beater truck has the same overflow bottle...... if mine has it and yours has it, maybe it's factory?
Old 07-26-2012, 04:30 PM   #11
68Stepbed
68Stepbed's Avatar
I've always just ran my overflow through the inner fender. When I teched in for the GG autocross, they told me I had to have a catch can, so I sucked down a Mtn Dew as fast as I could, then used a mini-bungee cord to tie the can to the bumber bracket under the fender. He said as long as it didn't fall off, it would be fine. It stayed on there, too.
I'm thinking of having a custom one made to fit under the inner fender, so it's out of the way, but more than likely mount one under the battery tray.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-27-2012, 04:03 PM   #12
Custom 68
Custom 68's Avatar
If you are ever going to take it to a race track they will insist you have an overflow tank.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-27-2012, 05:01 PM   #13
19seventeeCustom
no track duty here. thanks for the replies guys
always learning something new
