07-25-2012, 12:25 PM | #1 |
Truck dies when I put it in reverse
Hey,
Im new to the forum, this has possibly asked before.... bear with me. I just aquired a 72 with the original 350 and auto trans. There is some rust in the fuel, but I got it running rough but running. I can shift into drive and go forward, but everytime I put her in reverse she dies very quickly. Im thinking tourqe converter, what do you all think?? Any info is apprieciated!! Thank You! |
07-25-2012, 12:43 PM | #2 | |
Re: Truck dies when I put it in reverse
First of all WELCOME TO THE BEST TRUCK FORUM ON THE INTERNET!
After the carb is rebuilt, I would thoroughly clean that gas tank before I reinstalled it. If you don't, you will just have to rebuild all over again. There are dozens of excellent threads on cleaning the fuel tank on here. Just use the "Search This Thread" feature for all the info you would need to do it right. I have never heard of a torque converter stalling the engine in reverse... but then I'm not Mr. Goodwrench either. Good luck! NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
07-25-2012, 01:25 PM | #3 |
The Older Generation
My '39 Ford Coupe does the same exact thing. It is a rebuilt TH350 won at a car show. I don't know about your truck, but after the '39 warms up good it doesn't do it again until you let it sit long enough to cool down. If you don't hold the brake pedal down you will go backwards about 20 MPH. I have asked every transmission guy I know or meet and none of them have had a definite answer for it. All have said they would have to tear it down and check it out. When I first start mine and have to back up I shift it into reverse and as soon as it starts moving I shift it into neutral and let it roll backwards far enough to be able to drive forward. If you find out what the problem is post back here or PM me if you would... Thanks. LockDoc
07-25-2012, 08:41 PM | #4 |
It has the 4 barrel quadrajet on it.
I am going to clean out the tank this week and hopefully it will keep running and shift into reverse. I will read those threads on tank cleaning thanks NoNeck! LockDoc I will let you know when I find out what it is. |
07-25-2012, 11:46 PM | #5 | |
LockDoc
07-26-2012, 12:06 AM | #6 |
my truck does that in the cold before its warmed up.
07-26-2012, 08:02 AM | #7 | |
I was working at a small time garage at the time so I told the head mechanic about it. He had me pull it in his bay where I stayed in the car and showed him how reverse would kill it. He pulls the air cleaner, did something and the problem went away. I asked what he did and he said he simply "disconnected this emissions crap". If I remember correctly there was a vacuum switch mounted on the carb. That must have developed a leak that when removed and plugged fixed the problem. I hope this helps. That stuff was long gone on my truck when I got it. When I put an Edelbrock 1406 on it I used that TSC wire's +12V to run my electric choke.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
