Old 07-25-2012, 12:53 PM   #1
CRGRS 66
CRGRS 66's Avatar
Thoughts on my stance...
Finally have my tire wheel combination on the truck. I think I went too small on the front tires, no big, just tires.
Rear P295/50R/15
Front P225/60R/15 (think I should go to 235/60)
I am a hot rodder, so I want a little bit of rake. Changing to 235/60 on the front will bring the front up a wee bit, and fill the wheel well a wee bit more.
My plan is 2.5 spindles on the front, and maybe another inch with springs.
Any input on what I should do with the rear end?
Don't want to go any more than 2 or 3" there, but open to suggestions. The 295's really fill out the wheel well, don't think there would be a clearance issue, but it sure will be close.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 07-25-2012, 01:03 PM   #2
SIR
SIR
SIR's Avatar
Re: Thoughts on my stance...
...really nice truck...this has a 2 1/2 drop spindles, + a 1" spring drop, the rear has a 4" drop spring,when it settled down it was close to a 4/4 drop...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 07-25-2012, 01:12 PM   #3
jocko
jocko's Avatar
my 2 cents is that unless you're slamming it, 50 series tires never will really appear to fill the wheel well, rear or front. I personally prefer 75 series, but 70's and WIDE 60's will fill them (i.e. 275/60/15 or taller). Have to be wide for a 60 series aspect ratio to look "tall" also.
Recommendation if you want a rake and are looking at a mild drop:
1) 235/70/15 front - 275/60/15 rear (if you want a 60 series wide rear tire) - or a 255/70/15 looks nice also (in tghe rear)
or
2) 235/75/15 all the way around (if you want the same at all 4 corners, and spare tire ease...) These really fill the wheelwells on a dropped or stock truck. (you could also do a 235/75/15 front-255/70/15 rear too for stagger stance/wider in back)
I'd avoid any 50 series tire if you want to fill the wheelwells and any 60 series less than a 275 out back.
Let the drop kit establish your rake, I wouldn't try to do it with the tires alone (unless you were keeping stock suspension).
My 2 cents only. You have a very nice looking truck - but I agree with your opening post that the tire diameter looks a little small. Easy fix though.
Old 07-25-2012, 01:19 PM   #4
CRGRS 66
CRGRS 66's Avatar
thanks, and thanks for the input, can you tell me the wheel tire combo you are running?
Craigerrr
Old 07-25-2012, 01:39 PM   #5
Billett
Billett's Avatar
definitely this. Tires alone won't change it to the degree you would want. Nice looking truck though
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 07-25-2012, 02:17 PM   #6
CRGRS 66
CRGRS 66's Avatar
thanks billet, and jocko
maybe I am going about it backwards, but I wanted to settle on tire wheel combo, then determine the drop I wanted from there. As I understand it, 295/50 is 295mm width, and 147.5mm profile (the 50 referring to the profile being 50% of the tread width). So maybe I should run 225/65 (146.25mm profile), which would come very close to matching the profile on the rear tires. I really like the 295/50's out back
Before I order any springs/shocks/shock mounts for lowering the rear end I will have to remove the springs and shocks, ease the jack down, and check for clearance.
Craigerrr
Old 07-25-2012, 04:04 PM   #7
SIR
SIR
SIR's Avatar
the size is ...P225/60R15, on a 15x8" 5 on 5 lug pattern, "TORQUE THRUST" WHEEL MFG BY "AMERICAN MAG"....
Old 07-25-2012, 04:14 PM   #8
MisterC
MisterC's Avatar
Looking good, Craigerrr. I love how those back tires fill that wheel well up!
This pic of Alan's truck is quite possibly my favorite stance/wheel & tire combo on the boards. (I'm old school)
2.5"/4" drop with 255-70/15's all the way around.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 07-25-2012, 04:15 PM   #9
jchav62
1962 C-10
jchav62's Avatar
I know the stance and look you are going for. I dig it. I think you are on the right track with about 3" up front and about the same out back... to have a 'rake'. On my '73 (I sure do miss that truck) I ran 295/50's out back and 235/60's up front. I like the look of the wide 295's out back. The look that was big in the 70's and 80's.
Here's my old '73... It was lowered about 2.5" up front and about 3" in back...
(the first two pics are with 15x8's all around, and the last one has 15x7's up front and 15x10's out back)
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-25-2012, 04:25 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Roughly a 4/6
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-25-2012, 06:04 PM   #11
newbe351
Originally Posted by MisterC View Post
This pic of Alan's truck is quite possibly my favorite stance/wheel & tire combo on the boards. (I'm old school).
Nice! I like it very much myself. The GMC hood works well with the clear lens....
newbe351 is offline   Reply With Quote
Old 07-25-2012, 07:43 PM   #12
gimmy 64
the 235 or 245 or 225 does not change the tire hieght the aspect ratio does--60-70-75series does. drop the front 2-1/2 spindle 2 inch spring and it will look grate. of coarse drop the back about 4inch
gimmy 64 is offline   Reply With Quote
Old 07-25-2012, 08:40 PM   #13
SRVBLUES64
heres mine
SRVBLUES64 is offline   Reply With Quote
Old 07-25-2012, 09:08 PM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
That's not totally correct. The width (235, 245, etc.) does have an affect regardless of the aspect ratio. Since the aspect ratio is the ratio of the sidewall height related to the width, if the aspect ratio stays the same, the larger width will be taller too.
For example, my 235/70-15 front tire is 1" smaller than my rear 255/70-15 tire.
Both numbers play into each other. Best way to get the correct info, check the manufacturer website and get the real numbers as they can vary in size even at the same tire size.
Also keep in mind, if you are using tire size for a rake, whatever the difference in the two tire sizes are, you only get half that much difference when mounted on the vehicle. In my example, the 1" difference in height only translate to a 1/2" difference in rake. This is because the half the difference in on the top and half on the bottom of the centerline.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-25-2012, 09:16 PM   #15
taclem
taclem's Avatar
Your front tire size seems about right in relation to the rears. Your front springs look pretty new or stiff. I used a 215/70R15 front with a 275/60 rear, I also have 2" drop springs on the front. When I installed the front disc brakes I think the 1970 spindles I used also dropped it about 1". The rear springs are stock, but the optional leaf springs. It is very drivable, don't remember bottoming out on anything yet. Good luck, I think I know what stance your after.
taclem is offline   Reply With Quote
Old 07-25-2012, 09:53 PM   #16
brokenspoke
brokenspoke's Avatar
I personally like taller tires that just tuck into the fenders
brokenspoke is offline   Reply With Quote
Old 07-25-2012, 11:43 PM   #17
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I thought my ears were burning. BTW thanks
Alan's Classic is offline   Reply With Quote
Old 07-26-2012, 12:55 PM   #18
CRGRS 66
CRGRS 66's Avatar
Thanks guys, really appreciate the input!
Craigerrr
Old 07-26-2012, 01:04 PM   #19
CRGRS 66
CRGRS 66's Avatar
thanks, and yes, I love Alans set up too
Craigerrr
Old 07-26-2012, 01:05 PM   #20
CRGRS 66
CRGRS 66's Avatar
Originally Posted by SRVBLUES64 View Post
heres mine
Nice! What is your set up, and tire/wheel combination?
Craigerrr
Old 07-26-2012, 01:09 PM   #21
CRGRS 66
CRGRS 66's Avatar
Yes, and while I am not specifically using tire size for rake, just trying to arrive at a tire/wheel combo I like before deciding on my lowering combination.
I think that the front tires being/looking undersized (at least to me), came about as I did not split the ratio 1/2 above and 1/2 below the center line of the hub.
All input is much appreciated!
Craigerrr
Old 07-26-2012, 01:40 PM   #22
Rich 5150 69
Rich 5150 69's Avatar
Well Craig tough decision I know...mine will have to be adjusted after rear tank install.....coming soon....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-26-2012, 02:36 PM   #23
CRGRS 66
CRGRS 66's Avatar
Rich, I like your stance, and I like your wheels. What is your current setup, and tire/wheel combo?
Craigerrr
Old 07-26-2012, 02:52 PM   #24
Rich 5150 69
3 / 4 drop, 275/60 15, 6 lug ralleys 8x15......
Old 07-26-2012, 03:17 PM   #25
CRGRS 66
CRGRS 66's Avatar
Thanks!
Craigerrr
