07-25-2012, 04:06 PM | #1 |
The 86 Is Home
Hello just wanted to say killer site. My name is Jason owner of Outlaw Boost me and my son are doing a father and son build on the 86 we saved from the crusher..
The night we got it home. The next day. We started by pulling the push bar off the lumber rack and cleaned the truck real good got the oil leak fixed and fixed the rad. she runs like a top and on little rust spot. we are going to go the stret/track with this truck. long list of stuff to do so it will be a long build. |
07-27-2012, 02:28 PM | #2 |
Re: The 86 Is Home
Well be working on the truck today. Still kicking around a SBC or a BBC. Starting on the trans build and droppin the front. Will have pics up tonight.
07-27-2012, 05:06 PM | #3 |
Re: The 86 Is Home
Well still no ups truck lol. well here are some pics have more later.
Start with a good core. Got the dir.. piston cut down for a extra clutch. upgraded the front race to a harden 36 elem. Putting in a stage 3 transgo kit. Ill try to get more pics of the build of the trans. Talk to a guy about a BBC 454 so it mite get the big block with twin hair dryers |
07-30-2012, 09:31 AM | #4 |
Re: The 86 Is Home
Well got side tracked with customers and looking for a BBC for the truck. Well found a motor pick it up next week and then the moch ups and fab work starts custom built turbo headers down pipes ect ect. Ill post pics.
07-31-2012, 10:31 PM | #5 |
Re: The 86 Is Home
Ok I have a question I have to swap out the motor perches for a BBC or has some one used a soild upper mount and the 4.3 v6 perches? If i have to swap them do i have to look for 86 perches I was reading and some one said the 86 frame are different them say a 77 or so any help will be great.
Pic of the motor still need a rebuild |
08-01-2012, 10:44 AM | #6 |
Re: The 86 Is Home
I could be wrong, but I thought the V6 and the SBC used the same mounts and locations,but you have to move the perches to the next set of holes for the BBC...like I said, I could be wrong.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
08-01-2012, 11:24 AM | #7 |
Re: The 86 Is Home
thats what i was thinking the mounting holes are the same on the blocks v6, sbc,bbc just not a clam shell but i want to go solid for the build 496 with twin 76mm s400 turbos. Ill be out there playing with it between customers cars.
08-01-2012, 04:11 PM | #8 |
Re: The 86 Is Home
Started moch up on the perches. Here are some pics enjoy.
08-01-2012, 05:32 PM | #9 |
Re: The 86 Is Home
dont move the perches unless its a l6 motor. big and small use the same. have had a big and small and big then small then back to big in my truck and yet to move them
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
08-01-2012, 05:51 PM | #10 |
Re: The 86 Is Home
ok thanks its got the 4.3 v6 in it.
08-01-2012, 05:57 PM | #11 |
Re: The 86 Is Home
what do you do if the truck had an inline 6 and want to put a sbc in it? move perches up? awesome build cant wait to see more
08-01-2012, 07:01 PM | #12 |
Re: The 86 Is Home
Thank you I think you have to change them this is my first custom square. I have own a few but never didnt any custom work to them. Ill try to keep the pics coming.
08-01-2012, 07:12 PM | #13 |
Re: The 86 Is Home
Did it real fast in paint after they are done ill get the done in cad..
08-02-2012, 12:37 AM | #14 |
Re: The 86 Is Home
I like this truck, especially the color. Are you planning to leave the paint? Also like the rims on it.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
08-02-2012, 01:01 AM | #15 |
Re: The 86 Is Home
thinking about it and thank you
08-02-2012, 07:39 PM | #16 |
Re: The 86 Is Home
Did a little work to day.
08-14-2012, 06:11 PM | #17 |
Re: The 86 Is Home
Some pics of the trans build.
transgo stage 3 pulling the D piston and cutting it down. cut down piston. parts clean getting ready for the build. oil drain and cooling mod. Ill post more later. |
