07-25-2012, 04:58 PM | #1 |
sm 465 hydro clutch set up
hey guys im sure this has been discussed on here some where but i cant find it using the search and ive looked every where i know to look. ive got a 71 k 10 4 speed, 205 transfer, 355 with clutch linkage mounted on the ball below the rear driver exhaust port. its been swapped to dana 60s and next thing im going to do it a completely hydraulic clutch setup, im thinking externally mounted slave cyl and some sort of master cyl mounted to the fire wall. if some one can point me in the right direction thatd be awesome.. if anyone knows of a kit thatd be sweet.. i can fab brackets and such to make the mounts for the slave and master, just dont know what master, slave, or lines to try and find.. thanks in advance
61 apache |
07-25-2012, 05:30 PM | #2 |
Re: sm 465 hydro clutch set up
I converted my 72K5 SM465 useing 1986 GM Hydro Master, 1980 Toyota Land Cuzer Slave. Bought Advance Adapter pre-fabed slave bracket to fit my castiron bell (the land cruzer crowd swaps chevy drivetrian pretty popular) housing and Toyota Slave. Used -3Earls hose between the two.
Been working ever sence
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
07-25-2012, 05:41 PM | #3 |
awesome thanks! i guess you just went to the local parts store and got the master and slave? can you do me a favor and get a couple pics of the linkage to the master and the bracket from advance??? thanks! o yea and the hose you used is that something a parts store would have? ( i have no idea what 3earls hose is) thanks again
61 apache |
07-25-2012, 05:51 PM | #4 |
Earl is just a brand of braided hose and AN-3 is the size..it's a smal long braded hose.
Here you see the Advance Adapter bracket they make for the LC guys... I'll get more up in a sec..
07-25-2012, 05:58 PM | #5 |
awesome thanks!!!!
61 apache |
07-25-2012, 06:01 PM | #6 |
FireWall hole
Master Resevour mount "T" I made You can see the spacer I made on the master cyl. that was needed to bring the master farther away from the firewall cuz the pushrod wouldn't fully dis engage when the pedel was released. Don't have pics of the inside but I basically drilled a hole in my clutch pedel I used an angle finder to keep the push rod straight with the master body, drilled the hole. There are alot of different ways to conver to hydro this is just how I did it...
07-25-2012, 06:04 PM | #7 |
Found one:
You can see the bolt sitting in the hole
07-25-2012, 06:05 PM | #8 |
Last one
07-25-2012, 07:32 PM | #9 |
Thanks again! Looks like I have a project for the weekend if I don't end up at the lake!
61 apache |
07-26-2012, 11:00 AM | #10 |
My stock hydrolic setup on my 86 GMC K20 works good. Gotta have the hydro bell housing too though.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
07-26-2012, 12:21 PM | #11 |
If you watch Craigslist, every once in a while you can find a deal on a juice setup. I bought my complete one, with bellhousing, for $75 and the couple hours it took to get there and remove the parts.
07-30-2012, 12:47 PM | #12 |
www.Novak-adapt.com they have a kit. Not sure how much.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
07-31-2012, 12:38 PM | #13 |
thanks guys! im gonna check out all the above options
61 apache |
08-02-2012, 09:05 PM | #14 |
LET'S GO RACIN'
I bought a master and slave cylinder from speedway motors. The slave didn't seem to like my old style 3 finger clutch, so i'm buying a diaphragm style clutch.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
08-10-2012, 04:17 PM | #15 |
well it seems landcruiser slaves are semi hard to come up with.. im going to order a slave and bracket from advance adapters soon so that i can get my truck back on the road! im tired of looking at it in the yard and not driving it!
61 apache |
08-10-2012, 11:01 PM | #16 |
hey i have a bellhousing and all out of a 86 k30 hydrolic slave set up if u need thanks
08-13-2012, 07:46 AM | #17 |
This is the way to go. If something breaks, just go to the auto parts store and get parts.
08-13-2012, 10:17 AM | #18 |
