07-25-2012, 09:10 PM | #1 |
Is Spray-In Bed Liner Heat Resistant?
Does anyone know if it would be ok to spray the topside of the front inners, and firewall with bedliner or something? Or would heat be an issue?
-Gunnar Spending $ I Dont Have,
On Things That I Dont Need, To Impress People I Dont Know, It's The Truth. |
07-25-2012, 11:58 PM | #2 |
Collector of Projects
Re: Is Spray-In Bed Liner Heat Resistant?
It shouldn't melt if thats what you're asking, but it will not insulate the cab from heat. I would check the specs on what ever you decide to go with. Line-x or Rhino Liner probably have specs on thier webside. The do it youself types, you probably need to read the side of the box....
07-26-2012, 12:01 AM | #3 | |
Thanks for the input. Posted via Mobile Device
07-26-2012, 07:25 AM | #4 |
I got some spray on Fat Mat recently, sprayed it with an undercoating gun. I sprayed the inside of the cab, and had a little left over so I thought I would do the firewall. I thought I had taped everything, but I got a little on the exhaust manifold, anyway, that was 3 weeks ago, and it just now burned off. Stunk like crazy. Yhe stuff on the firewall is still there, hasnt melted or anything.
1969 4x4 Nothing beats a good rock drill and some dynamite |
