Old 07-25-2012, 11:30 PM   #1
csdineley
csdineley's Avatar
Emission exempt Exhaust Manifolds?
Hello
Today I picked up some manifolds I found on CL. The ad claimed they were off a 89 Burb with a 350. But they are a different design then my 87 manifolds and have no A.i.r injection port or O2 sensor fitting. So after some searching I believe they're off a C/K 88-95 engine. So my questions, Will they work on my 87? To me it looks like I'll need a new y-pipe. And why don't they have the emission stuff?
csdineley is offline   Reply With Quote
Old 07-26-2012, 01:51 AM   #2
Desert1957
Desert1957's Avatar
Re: Emission exempt Exhaust Manifolds?
Most "Air injection tube" manifolds went away when fuel injection came along.
My 87 has the "O2" sensor in the left manifold but I think they switched it to the Y-Pipe after a few years.
Desert
Desert1957 is offline   Reply With Quote
Old 07-26-2012, 02:19 AM   #3
WarBeard
WarBeard's Avatar
My '89 Burb has the O2 in the Y-pipe.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-26-2012, 06:46 PM   #4
csdineley
csdineley's Avatar
Ok, so did the 88-95 trucks not have the air injection system? Also you guys think they'll work if I also use a y-pipe from a similar year?
Old 07-26-2012, 10:33 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
my 88 has both
lets see yours
my others from 78-79
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-27-2012, 09:16 PM   #6
csdineley
csdineley's Avatar
Here's the ones I got the other day
Old 07-28-2012, 01:20 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
guess i'd call that log style... seen some (air holes)filled "well" ,not filled new tho
John
Old 07-30-2012, 06:00 PM   #8
csdineley
csdineley's Avatar
So think I could drill & tap the holes for the air injection and o2 sensor? Or remove the entire air system, which worries me. No smog test here for cars older then 1995 but they do a visible inspection for cars newer then 35 years old
Old 07-31-2012, 08:27 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
drill and tap ,sounds risky
if they hook up the same get a set for inspection time
John
Old 07-31-2012, 10:34 AM   #10
MalibuSSwagon
Depends on how strict the visual inspection is. I have no emissions equipment on my truck thanks to the previous owner, hell the charcoal can is gone. It passes the visual check just fine. My 92 Honda has no cat and the inspection guy says nothing about that either.
MalibuSSwagon is offline   Reply With Quote
Old 07-31-2012, 09:38 PM   #11
csdineley
csdineley's Avatar
Well I guess I hit up the junk yards and look for another set. My truck is mostly stock, and I'd kind of like to keep it that way, for the most part.
Old 08-01-2012, 07:34 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
before you use them, clean out the bumps if they have them
it helps with sound/flow
John
