07-26-2012, 12:15 AM | #1 |
Rivets or bolts?
I'm rebuilding the drivetrain on my '89 Chev K1500 EC. I'm stripping/ cleaning some of the parts and supports and painting them with POR-15. The crossmember that is directly behind the torsion bar support is riveted to the frame with four rivets. I've been cleaning the waxy undercoat/ rust/ dirt off this crossmember and I was thinking it would be easier to grind the rivets and remove it with the idea of bolting it in afterwards. Anyone have an opinion regarding this idea? Would I be compromising the frame strength and would it be advisable to add some gussets if I do remove the rivets on this crossmember? (This crossmember/ support is used for a carrier bearing with a two-piece driveshaft.) My truck uses the one-piece driveshaft.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
07-30-2012, 09:05 AM | #2 |
Re: Rivets or bolts?
I've removed hundred's of rivets and replaced them with bolts. Never had a problem. Make sure the bolt fights snug in the hole. I drill the rivet hole out with a 11mm drill and use a 7/16-20 grade 8 bolt. Flat washers on both sides and blue lock-tight. Torque to 60-80 ft lbs.
Have fun....removing rivets suck!
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-02-2012, 04:17 AM | #4 |
Thanks! I'll resume work on my truck this week and I'll take your advice.
08-09-2012, 09:11 PM | #5 |
I know its only been a week but any updates or pictures i would love to see what the frame looks like after
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
08-10-2012, 12:44 AM | #6 |
My work on my truck has slowed for the moment. I'm old and it's 100 degrees outside. I did remove the crossmember finally. I ground/ and drilled the rivets flush and then pounded them out. I power wire-brushed the crossmember this evening. I should be able to etch it with CLR tomorrow in prep for POR-15. I bought a set of ARP 7/16x1 bolts to connect to the frame when I'm done. That's where it's at for now.
08-10-2012, 01:13 AM | #7 | |
08-10-2012, 01:14 AM | #8 |
i should have just used CLR, i would have saved money
08-10-2012, 02:59 AM | #9 |
I originally started using a product called Metal Etch that I was able to buy at hardware stores. I can't find the product any more. CLR is similar and slightly weaker but succeeds in prepping the metal surface for painting. I've been using POR-15 like this for many years. It holds up better than most products I've found in a spray can. Standard Brands used to sell big spray cans of black urethane that I painted the engine compartment in my old Firebird. That stuff held up over time (20+ years), but it's long gone. Paint formulations change over time and a lot of products don't exist any more.
