Thread Tools
Display Modes
![]() Join Date: Sep 2011
A lil (more)help please
I need a PS pump bracket, it needs to bolt up to the 1963 283. There are only 2 holes in the block. My buddy Dave says he can fab something but it would be better to have an OEM bracket. Here is a pic of the block mounting holes.
![]() I've got differential covers ordered. I really need a power steering bracket if you have any idea where I can order. I've tried LMC I've tried Summit no luck there. I'm not having any luck locally anybody got any further ideas maybe got one in the junkpile? Thanks
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 Last edited by MikeS.; 07-26-2012 at 04:12 PM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: A lil (more)help please
I don't happen to have any extra good ones. Just in case you did not know, any cover from a truck 12 bolt will work. They were used in the C10's from '63-'82 and in the K5's and K10's from '63-'79/'80. I believe you can find a chrome one at Summit if nothing else.
Well I just ordered front & rear covers and gaskets. Hope I got the right ones. It's hard for me to tell by looking at the pictures.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
60-66 Nut
As long as you ordered a cover for a truck 12 bolt, you will be fine for the rear diff. I don't remember just what year of front differential you got, but it seems like it was an '80 something. In that case, you will need a cover for a 8.5 corporate 10 bolt for the front diff. If it is a '79 and earlier it will be a Dana 44.
#5 | |
You da man John! Posted via Mobile Device
We decided to replace the water pump to the long nose style that has the 3rd hole for the ps bracket. I liked that idea since this pump was 25 years old, or there about.
Senior Enthusiast
If you're willing to consider an aftermarket setup, Alan Grove offers the 402L which I believe will work in your application. I've been using their power steering and alternator brackets for over 10 years. They are relatively inexpensive, well built, and provide perfect alignment. Here are a few applicable links:
http://www.alangrovecomponents.com/i...tions/402L.pdf http://www.alangrovecomponents.com/i...s/pspsheet.pdf http://www.alangrovecomponents.com/i...Large/402L.jpg http://www.alangrovecomponents.com/S..._Long_Pump.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
![]() Join Date: Sep 2006
If you went with a long pump then try looking at vans. When I was running my 283 I got a pump and bracket from a van. The diff was the upper part of the bracket bolted up to the front left exaust hole. Too bad I never took pictures of it but I still have the pump and bracket sitting in a bucket. I think it came out of a 1975 chevy van. I have a picture if it hooked up to my later model 350 though. I'm not sure if this will work with the alt on the same side.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 07-27-2012 at 09:51 AM. |
60-66 Nut
If you change to the long water pump, you will also have to move the alternator to the passenger side. You will need those brackets, and also move the alternator wiring to the passenger side.
truck shop in orange california has all the brackets ..... they have alot of stuff that LMC, classic and the other dont have
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Thanks Sigshooter that's good to know.
$39.00 for both brackets, the lower part that bolts to the front of the engine and craddles the pump and the rear part that bolts to the pump and engine mount that adjusts the belt. new pulley is around 30 bucks, Truck shop has all kinds of stuff the others don't
