Old 07-26-2012, 01:45 AM   #1
CEE1NG_RED
RADIATOR help...
I have a '67 CHEVY SWB truck with a '78 350 motor. Now, my radiator has a leak on the ports where the fins are (two locations). My question...is my radiator a '78 or '67? My assumption is a '78, but I want to be sure.
Also, what radiator brand and part# works best that most of you have bought new from a local automotive store for your '78 C10 350 truck. My truck is an automatic with a TH350 transmission and the AC and heater system have been taken off/deleted. Any feedback would be greatly appreciated. Lastly, is a 1 core or 2 core good enough for my truck? Not really sure what is the reason for the number of cores as some C10 have used a 2 core and some 1 core radiator tanks from a Chevelle. Thank you.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-26-2012, 02:26 AM   #2
WarBeard
WarBeard's Avatar
Re: RADIATOR help...
Gonna need pictures of the radiator in order to tell you which one you have.And I would say no less than 2 cores.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-26-2012, 02:35 AM   #3
CEE1NG_RED
The radiator is still attached to the truck. I will attempt to use JB WELD and see if that stops the droplet leaks from the rod, where the fins lay on. There are two drop leaks when I pressure tested the radiator. If that works temporarily, I can flush the old brown dirty coolant before getting a new radiator, which is my last option. I would like to fix this one at least.
Anyways, what kind of pics did you need to help determine what radiator I have? Also, do you know of a place that sells all metal radiators? Last, is my radiator a '78 or '67 since my motor is a '78 in a '67 truck. My assumption is a '78 since the upper/lower hose is from a '78 model (NAPA).
Old 07-26-2012, 10:09 AM   #4
Pro Performance
Pro Performance's Avatar
I think a 2 core would be sufficient if you have a mild motor, but a 3-core will be a good idea. A little overkill, but better to be that than to enough. Your radiator is most likely a '67 radiator, as that is what fits the truck and the '78 will have different mounting / size.
Pro Performance is offline   Reply With Quote
