Old 07-26-2012, 08:45 AM   #1
slowyellow
AC cooling issues?
I'm getting ready to put in a vintage air system. I was just curious if I'm going to run into any cooling issues. Truck has a 350 with a 350 behind it, trans cooler is just the one internal to the radiator. The truck just has a 4 blade fan on it. It doesn't have any issues staying cool right now, I just don't know the added load from the ac compressor will change that.
Are there any common/cheap cooling upgrades like a different fan or something like that?
slowyellow is offline   Reply With Quote
Old 07-26-2012, 08:57 AM   #2
zellway
zellway's Avatar
Re: AC cooling issues?
I like to seal around the radiator with thick foam to force the air to pass the though the radiator. I have the Old Air twin electric fans and I run the vintage air system with no problems. The condenser is nice and close to the radiator so it gets good air flow. I did install a radiator from a 85 suburban. Its a cheep upgrade, Aluminum duel pass for around $120 to $150. The best part is if your truck was set up with the mounts for the thin radiator its a drop in upgrade.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 07-26-2012, 09:08 AM   #3
slowyellow
The truck already has a pretty thin radiator in it. PO did that. So it looks like electric fan is the way to go? What is a common alternator to upgrade to for more power accesories? I'm planning on adding a sub down the line. Nothing crazy, just a 8 or 10 inch sub to even out the sound in the truck.
Old 07-26-2012, 09:19 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
I had an automatic 3 row radiator (700R) in my truck with a flex fan. Added a 7 blade clutch fan and it helped, but still got hot in traffic, so I put in a factory 4 row. You do need the wider brackets for both the bottom and top to hold it in place. Hasn't overheated since.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-26-2012, 01:12 PM   #5
zellway
zellway's Avatar
I added a power master 100 amp alt. I got the fans to try them out. They work fine in the 120 deg heat. I hot rod around and sit in traffic with no problems. I do run a 195 thermostat. I did drill 2 small 1/8" holes in it to let water flow past it just a bit. With out the hole the temp would get up to 195 and drop to 175 each time it would open. Now its always around 190. If you have a good fan shroud it should be fine. Don't try and run it without one.
Erik
Old 07-26-2012, 04:39 PM   #6
gotchamel
Curious myself,hope to fire up my c10 with new VA this weekend.Not knowing the history of my cooling system I replaced the 3 row with a 4 row radiator,flexfan{7 blade}and a new wp.Did not want to get everything back together and have issues.
gotchamel is offline   Reply With Quote
Old 07-26-2012, 04:42 PM   #7
slowyellow
Which fans did you get? And are you saying that I'd be ok with my stocker as long as I have a good shroud? Isn't there a fan that is identical to the stock that just has more blades that increases airflow? I thought I heard that somewhere.
Old 07-26-2012, 07:25 PM   #8
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
I have a VA GenIV system on my Suburban. Running an '88 454 with factory 5 blade '88 viscous fan and BB fan shroud. Original style 4 core radiator with a gigantic transmission cooler blocking nearly one half of it, running the trans fluid through the in-radiator cooler too, and I've got an engine oil cooler in front of the radiator as well. Just drove it through 100+ degree weather, up steep grades and sat idling in a hot, crowded national park this week with the A/C on full blast. Never once had a single time where the coolant temperature was above 200 degrees.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
