Old 07-26-2012, 09:23 AM   #1
jjzepplin
jjzepplin's Avatar
Charging A/C First timer
I have never had a classic with working A/C. So here goes. I have a complete stock setup from a 72. The compressor and belt system is from a 1992. Compressor is the R4 I believe. I have pulled a vacuum and it's holding. I have replaced the drier. The condenser and evaporator had a bit of freon and oil in them when raped from the junk yard. I am thinking r134 but may go with r12. But what about oil? Any help from A/C guru's?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-26-2012, 09:50 AM   #2
Transformula
Transformula's Avatar
Re: Charging A/C First timer
Yes, you do have the r4 compressor (Radial, 4 cylinder). PAG oil is great for retrofits of 134a where r12 once was. Be sure to flush all lines, evaporator, POA valve, condenser, etc. Drain the compressor of old oil and add some with the front facing down, through the inlet port and rotate the drive a few times. This lubes the front seal. They even make a retrofit vavle with a compressor cycling switch to replace the POA valve that is usually no good anyway.
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 07-26-2012, 10:03 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
Was the condensor and evaporator coils from the '92 or a 67-72? Just wondering as I read others say that the 67-72 condensor is too small to efficiently cool on 134 systems. The '92 would have been R12 so just as transformula said if you go with R134 it would need flushed and have PAG oil added. The compressor label should specify how much oil the system needs. I dont recall the weight maybe PAG100? there are several PAG oil weights hopefully someone else can verifty the proper oil weight for you.
R12 cools better but costs a lot more while R134 is readily available and costs less. I converted my '93 from R12 to R134 and it works great. I also changed all the o-rings and seals out with the new green ones that are supposed to be for R134 but have seen plenty of people use the old black o-rings without problem.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-26-2012, 12:26 PM   #4
jjzepplin
jjzepplin's Avatar
Just the compressor is 1992. Rest is stock 72. Do I need to change the poa? It was on a charged system. I assume it still works. Did I screw up my new drier by installing it and pulling a vacuum?
Old 07-26-2012, 12:37 PM   #5
El Campo
El Campo's Avatar
Did the stock 72 line bolt right up to the compressor?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-26-2012, 01:01 PM   #6
mrein3
mrein3's Avatar
If you're going to use R134a, you do need to adjust your POA. ackits.com used to have a really nice post with pictures on how to do this. However the pictures weren't there the last time I looked. Post #4 in the link below has a link to the ackits.com forum where I learned how to adjust my POA.
You didn't screw up your receiver/dryer as long as you don't leave it open to the atmosphere.
Where you are at this is what I'd do.
Flush the evaporator and condensor with mineral spirits. First remove that new receiver/dryer and plug both holes then flush back and forth with mineral spirits and compressed air. This is messy but necessary. Don't worry about getting all the mineral spirits out as when you pull a vacuum it will all boil out with any remaining moisture.
Replace ALL o-rings with new ones. ALL of them.
Flush the compressor with oil like Transformula said. I bought 1/2 gallon of R134a compatible oil from AC kits which was enough for 3 or 4 flushes of my compressor and the 11 ounces you need for the system when you're ready to close it up. I still have about half of that half gallon for future projects.
Note that the R4 compressor you're choosing to use is the same compressor that scared all the old-school guys I know away from serpentine belt drive systems. Those things like to lock up and with one belt you're stuck.
The stock condenser on this vintage of truck is not the most efficient but because the cab is small it will work. R134a isn't as efficient at cooling as R12 is so modern cars and trucks have condensers with many more tubes giving much more surface area to help with taking the heat back out of the coolant.
I did a detailed post about my AC job in here:
http://67-72chevytrucks.com/vboard/s...d.php?t=478564
Scroll down to post number 8 to see all the part numbers and prices for the stuff I bought.
I hope this helps.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-26-2013, 11:51 AM   #7
jjzepplin
jjzepplin's Avatar
oops
