Truckin' Krazy
![]() Join Date: May 2000
Tilt column
This Tilt is out of an RV, correct length, but you will need to move the neutral safety switch.
Chrome is good on shifter, Knob has a little rash on it. cruise control turn signal switch, or I can include the correct one in its place. Tight tilt head, shifter pin tight, turn signal cancel works, plastic indicator housing, no pry marks or damage to collar or tilt head, includes new aftermarket pointer. There is a small spot at the bottom where the cutting torch grazed it, didn't burn through & no problem other than cosmetic. $225 shipped. Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Truckin' Krazy
Re: Tilt column
Nobody needs a decent tilt?
![]() Join Date: Mar 2011
Re: Tilt column
Wow, wish I hadn't bought that van tilt now... amazed someone hasn't grabbed this yet.
Really good deal...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
Re: Tilt column
Im amazed as well, I've sold several on craigslist out of MoHo's for more $
Re: Tilt column
If ya would go $200 shipped I will take it ?
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
Re: Tilt column
Payment sent Tom, if you could swap out the cruise handle for non cruise that would be great.
Thanks, agian.
