Old 07-26-2012, 10:45 PM   #1
paintslinga2010
Windshield washers spray fluid when wipers are on
Like the title says, when I turn on the wipers the nozzles shoot out washer fluid in short pulses and do not stop until I turn the wipers off. What do I have hooked up wrong?
paintslinga2010 is offline   Reply With Quote
Old 07-27-2012, 12:20 AM   #2
jhngardner367
jhngardner367's Avatar
Re: Windshield washers spray fluid when wipers are on
It's more than likely you have a bad ground. It's the same as if they won't shut off. Clean the contacts on the connector,and the metal area that the mounting bolts go through.One of them has a metal strip on it that acts as a ground,for the wiper motor.A bad contact(ground),on it will cause the problem.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
