07-26-2012, 11:01 PM | #1 |
Hybird U JOINT
Need help finding out the part number or were i can pick up this u joint.
it is a hybird joint for a np208 drive shaft being used with a gm corp 12 bolt axle anybody know where i can get it?
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
07-26-2012, 11:03 PM | #2 |
Re: Hybird U JOINT
07-26-2012, 11:22 PM | #3 |
Re: Hybird U JOINT
basically going from a gm corp 10 to a 12 bolt
07-28-2012, 10:07 PM | #4 |
Re: Hybird U JOINT
They are convertion U joins.
and sometimes it depends on the model vehicule, do you know what size you use to have, my shaft uses 1310 u joint on the axle side and 1350 on the transfer side, beign a 208 as well. so maybe yes a 1310 - 1350 convertion is what you need. what year truck is it? |
