Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-27-2012, 02:52 PM   #1
kennyhammond
chevy 350 piston advice
making a little hopped up 350 for a 89 chevy ... the guy wants a big cam and flat tops i tore the motor down and found a bent valve and dish pistons .. he has a set of heads with 1.94 valves .. now i am thinking the dish pistons will be better for the rebuild but .. want a little advice ..and i dont know what cam i should use
kennyhammond is offline   Reply With Quote
Old 07-27-2012, 04:50 PM   #2
manimal
manimal's Avatar
Re: chevy 350 piston advice
open chamber or closed chamber heads? Carb or EFI?,what cam? full dual exhaust or single?...lots of variables. Need more info.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-27-2012, 06:41 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Need more info . Are the heads 89' also ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-27-2012, 07:07 PM   #4
kennyhammond
Don't know much about heads....they came off a Corvette ....the Guy went with aluminum instead....
Old 07-27-2012, 10:54 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
get the numbers of the engine and heads
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-28-2012, 12:37 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
I love that... everyone has 'Corvette" heads. And no one wants to talk about the lame 265HP 350's or the 210HP TBI motors that were mainstream mid-70's to 80's corvettes.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-28-2012, 01:33 PM   #7
fastwillie 696969
~Rest In Peace~
i refuse to own any corvette from mid 80s . 84-87 just dont like them ,when i work for chevy it seem all i was doing was recall work half the time ,and warranty work dont pay
Old 07-28-2012, 01:54 PM   #8
kennyhammond
man i dont know anything about the heads... worst case is i have a set of vortecs in my garage but i dont want to give them up so he is providing the heads... witch he said are corvette heads... so i baught a 268h comp cam and am going to use the dish pisonts with a weimand 7502 intake
Old 07-28-2012, 03:36 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
I had good luck with that cam , Vortec heads and a 4 valve relief flat top . Is this carburated or TBI ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-28-2012, 08:52 PM   #10
cableguy0
"Corvette heads" means nothing. They are nothing special especially if they are alum heads from the 80's. Its not going to perform well because like everything else from the smog era they sucked.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-29-2012, 04:28 AM   #11
Rannos
Rannos's Avatar
Any more it doesn't make sence to use factory heads for even a mild sbc build. You can buy Egine Quest Heads for around $500-600 complete for just about any sbc build ya want. They are cast by the same company that use to cast RHS heads. They use the same molds as RHS did before they dropped their Iron heads. For the price you will spend on machine work on a set of vortecs you can get brand new heads. Plus if your combo. is remotly accurate they will out proform the vortecs 2 fold. For a mild 350 build get something like the 170's or 185's with a decent hydraulic cam. On a 355 with 9-10 to 1 you can get a mild mannered 375-400hp.
If your buddy is set on aluminium heads, you can get Patriots complete for just over $800. IMO some of best bang for your buck heads out there. A flat top 355 with a good set of patriot 185's with a Hydraulic roller and you can get 420-430hp and still be rather street friendly.
One thing to not over look if your building even a mild motor is rods. Spend some moeny on rod bolts or even a new set of rods. Scat SIR rods aren't that expensive and are pretty d*mn good rods.
Rannos is offline   Reply With Quote
Old 08-09-2012, 10:59 AM   #12
ll____b0t____ll
ll____b0t____ll's Avatar
I wouldnt use dished pistons on anything unless it was being forced inducted like a blower , turbo or perhaps larg amounts of NOS.
And if your going to be running a decent aluminuim head take advantage of the heat disapation and abilty to run higher compression on pump gas without pinging and go atleast flat tops or even a speed pro with a slight dome.
ll____b0t____ll is offline   Reply With Quote
