07-27-2012, 07:03 PM | #1 |
fan heat probes
do all probes that fit either in your radiator fins or the manifold have 2 prongs and just one prong gets power form the ing then the other gets ground?
07-27-2012, 08:47 PM | #2 |
Re: fan heat probes
The fan circuit is grounded when the sensor switch closes at the prescribed temp.
07-28-2012, 06:43 AM | #3 |
Re: fan heat probes
where do I find a single terminal heat probe?
07-28-2012, 06:54 AM | #4 |
Re: fan heat probes
I normally use a switch from a late 80's/early 90's Camaro. It goes into the intake mainfold near the thermostat, it is 3/8 pipe thread. I will look and try to find the part number. Mine kicks the fan on at 205 and off at 187 according to the OEM specs. I bought mine from O'Reilly's here with the pigtail.
07-28-2012, 10:50 AM | #5 |
Re: fan heat probes
the only single terminal I am aware of are temp sensors that install in the block or intake, somewhere in a cooling passage, they take their ground from the mount and output variable resistance. what you are using is a thermo switch, a bi metal strip in the switch bends as it heats up and closes the contact between the two pins. its usually used to turn on a relay, not directly to a fan, one side gets grounded and the other side goes to the trigger side of a relay. I havent ever seen a single terminal thermo switch, maybe they exist, but it wont install in the coils of the radiator.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-28-2012, 11:16 AM | #6 |
Re: fan heat probes
Joe- you are exactly right, I called what I use a switch because to me that is what it does, but it is a temp sensor that grounds the relay for the fan. I should have had a few more cups of coffee before posting this morning. Sorry if I confused anyone.
07-28-2012, 11:31 AM | #7 |
Re: fan heat probes
This is a Murray 35946 called a cooling fan switch- popular on alot of 90's GM products.
I used a BWD TFS5 which is the same appearance. |
07-28-2012, 11:53 AM | #8 |
Re: fan heat probes
yep, there ya go, good work tincan!
07-29-2012, 06:42 AM | #9 |
Fabricate till you "puke"
Re: fan heat probes
Painless offers a kit (about 60 bones)...fans on @ 205/off 185, or on 185/off 165. The kit includes the relay, circuit/ braker, & complete instuctions. Works like a champ! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-29-2012, 10:20 AM | #10 |
Re: fan heat probes
fixed thanks guys for the help
