Custom floor sheetmetal
I removed my seat today along with the carpet and I noticed big ugly humps on the floor and when I put the single camaro set on I didnt notice any different in seating so Im up to cutting the floors and make it deep like bowls did anyone ever did this before?
Re: Custom floor sheetmetal
I have done it and several other members have done it as well. Unfortunately my truck and photos were lost in a fire. If you do a search you can find posts on installing late model seats in a square.
Use a lazer level to mark things out and make sure to re-inforce the floor sections you build. I would suggest bead rolling the new floor panels to avoid the oilcan effect. You have to remove one brace per side, that should be re-built and dont forget how this changes the carpet. Good luck. Keith |
I wonder if you could use a Camaro or Chevelle floor pan as a base for the modification?
Ok this just came on my mind I think the humps were made to clear the gas tanks mine has dual tanks
I will just cut the tanks making them smaller
