Old 07-27-2012, 10:40 PM   #1
byates2
byates2's Avatar
Radiator Fans
I want to put electric dual fans on the radiator instead of the mechanical engine fan.
I have the Desert Cooler 4 row radiator. its 16-1/8inch high 28-3/8inch wide and 2-5/8 diameter. I talked to a guy at jegs and he said as long as the fan measurments match the core of the radiator then it will fit
Anybody have any advice
Any ideas where to get a good fan setup that will fit. I have about 3.75inches of clearance between the radiator and the water pump pulley.
any ideas, anybody ever go through this?
p.s. its a 67 c10
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 07-28-2012, 12:06 AM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Radiator Fans
I did almost this exact install & it kicks ass:
http://www.thehollisterroadcompany.com/MarkVIII.html
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 07-28-2012, 01:30 AM   #3
oklalawnboy
oklalawnboy's Avatar
Re: Radiator Fans
Whatever size fans you decide to use, I think it would work best with a shroud. Otherwise you only pull air through where the fans rest against the rad.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 07-28-2012, 01:34 AM   #4
hayhauler71
hayhauler71's Avatar
Re: Radiator Fans
http://www.flex-a-lite.com/auto/html...-electric.html This is the one that I am looking at it has 4600 cfm. When you look at fans make sure you look at the amps they draw you may need to upgrade your alternator
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-28-2012, 10:08 AM   #5
oneperfectrun
oneperfectrun's Avatar
Re: Radiator Fans
Wonder how loud these would be with the straight blades?
oneperfectrun is offline   Reply With Quote
Old 07-28-2012, 11:02 AM   #6
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Radiator Fans
I used Wizard Cooling. They are local to me and fabricate radiators for our trucks. They are a specialty company and do excellent work. They built the radiator and shroud, and installed dual SPAL fans. I had to make some minor modifications to my radiator mounts, but no problem. I would highly recommend them.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-28-2012, 12:07 PM   #7
Rooster's 67
Rooster's 67's Avatar
Re: Radiator Fans
Derotoreut,
If ya don't mind my asking, bout how many green backs that set up run from them? Cause that's a good looking setup. also will they make them for the 60-66 trucks?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 07-29-2012, 10:33 PM   #8
derotoreut
derotoreut's Avatar
Re: Radiator Fans
Originally Posted by Rooster's 67 View Post
Derotoreut,
I worked a cash deal for $750 complete, with Scott, who is the owner of Wizard Cooling. They are local to me and only about 40 mins away. I know they build all kinds of radiators. I would strongly suggest you call Scott Attig at 716-655-6760. You can also check them out online at wizard cooling.com.
~ Dan
