07-28-2012, 02:10 AM | #1 |
Where did you get your trans. cooling lines from? Need replacement.
My '67 with a '78 350 motor and TH350 trans and 3 core radiator (currently looking for a exact replacement for that; possibly a '69 model since it comes with a 350 and TH350). Anyways, my trans cooling lines had been cut at certain areas where a hose is connected to make it work. I would like to know where everyone had gotten their trans. cooling lines from. I checked NAPA, Autozone, Oreillys, but no luck. I did find one at Summit. A SS version for a 1969 350 motor/ TH350 trans...but for $50. Is the stock trans. cooling lines made of regular steel or SS?? Here's the link:
http://www.summitracing.com/parts/RS...704S/?rtype=10
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
07-28-2012, 02:25 AM | #2 |
Re: Where did you get your trans. cooling lines from? Need replacement.
Stock were steel. I got mine from Inline Tube.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-28-2012, 10:01 AM | #3 |
You can get brake lines, to use for trans lines, at any parts store and bend to fit. You can get these in straight sections. Just make sure to get the size with the correct fittings. Use a tubing bender and be sure not to kink the tubing so that it doesnt obstruct the fluid flow.
Posted via Mobile Device |
07-28-2012, 11:36 AM | #4 |
I got my brake lines, trans lines, and vacuum line for modulator all from inline tube and they all fit great.
07-28-2012, 11:44 AM | #5 | ||
"I ain't nobody, dork."
Before I knew about Inline Tube... I got my steel trans cooling lines for my '72 GMC from LMC. Fit was dang near perfect with only a slight tweaking of the upper line to line up with the radiator to start the threads. Maybe a 1/2" bend.
I got my SS brake lines from Inline Tube. They fit great too. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-28-2012, 11:45 AM | #6 |
Inline tube, steel or stainless steel, your choice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-28-2012, 12:04 PM | #7 |
Tubing bender, double flaring tool, Brake lines in appropriate sizes, and a little patience. No waiting for shipping, and you then have two more cool tools for later use, and the pride and bragging rights of "I made them thar lines".
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
07-28-2012, 05:15 PM | #8 |
Classic Chevy Recycler
If you are trying to save some money, you can get them off of a later model truck. They will work with a little bit of tweaking.
2004 Chevrolet Trailblazer EXT 1970 Chevrolet C50 1979 Chevrolet C30 Need another 67 or 68 soon... |
