Old 07-28-2012, 07:39 PM   #1
louder50
Cowl Vent Mouting pieces?
I am getting ready to install the cowl vent between the hood and windshield but mine is missing all the plastic pieces and the 2 brackets for the screen. It looks like some of these are available through Classic Ind. but they're $13 ea so it looks like I will have over $80 into about 4 grams of plastic nubs and a couple little brackets. Anybody know a better, cheaper source? All the junkyards around me have crushed everything this old.
louder50 is offline   Reply With Quote
Old 07-28-2012, 10:33 PM   #2
82ccshorty
82ccshorty's Avatar
Re: Cowl Vent Mouting pieces?
If you find the plastic pieces let me know please. I needs them for my 82
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-28-2012, 10:59 PM   #3
grs
If I knew what they looked like Maybe I could get them. And what year. I think I know what they are, and two of them are metal.
grs is offline   Reply With Quote
Old 07-29-2012, 12:23 PM   #4
bowtiemanchevyman
bowtiemanchevyman's Avatar
go to www.classicparts.com they sell all the parts you need for it. that where i go mine
bowtiemanchevyman is offline   Reply With Quote
Old 07-29-2012, 01:26 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
Is it a '70s or '80s truck? That area is prone to causing
Cab leaks. On my '78 I'm going to fabricate a plate that will cover up the opening and keep water outta there. I'll probably carefully sheetmetal screw it down and rtv it. Might paint it matte black so it still looks like that stupid plastic peice is there through the cowel
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-29-2012, 08:30 PM   #6
bowtiemanchevyman
if you do that your heater wont get any air. that where all the air come in so you dont wont to do that.
Old 07-30-2012, 09:00 AM   #7
willett
willett's Avatar
i thought that that was just the intake for the kick panel vents :s
Old 07-30-2012, 11:51 AM   #8
bowtiemanchevyman
if you pull off the panel you can see the blower motor fan. the reason they do it that way the air gets forced in there when you are driving down the road.
Old 07-30-2012, 02:25 PM   #9
grs
When I removed my cowl vent panel I did not see the blower motor fan. I have an 87.
Old 07-30-2012, 02:46 PM   #10
bowtiemanchevyman
pull of the kick pannel and you will see it and have some one point a flash light from up top and you will see the light come down from the top cornertrust me its how it works.
Old 08-04-2012, 02:47 PM   #11
willett
willett's Avatar
I'm still sorta curious about the air routing here. Can anyone else pipe up? The kick panel vents are also open to the undercarriage. I'd rather just open a window then have to deal with my firewall rusting out again.
Old 08-07-2012, 05:16 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
or snow when it's real fine lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
