07-28-2012, 09:15 PM | #1 |
For Sale Rebuilt Manual and Automatic Tilt Steering Columns Jeep intermediate shaft
I am relisting these columns as I now have Jeep intermediate shafts as an option for these to eliminate the sloppy rag joints.
1)First is a manual floor shift tilt steering column with key for the 78-83 trucks. It will work for 1978 and earlier with the correct intermediate shaft(I have this as well for an additional $20). When I purchased this steering column the lower collar that meets the dash bezel was cracked and missing pieces. To repair this I had to COMPLETELY disassemble this column. I replaced the broken collar, cleaned and regreased everything, and put loctite on the tilt mechanism bolts before carefully putting everything back together. This now works as new with no play. If you are familiar with these at all it is VERY time consuming and involved to take these completely apart and reassemble them correctly. For this reason I want $200 FIRM with the Jeep intermediate shaft $180 FIRM WITHOUT Jeep intermediate shaft NOT including shipping. 2)Next is a nice automatic tilt steering column for the 1984 and newer trucks. This was actually removed from a 1987. Column is in very good shape with NO wobble and includes the key. The lower bearing has been cleaned and regreased so everything turns nice and smooth. Price is $180 with Jeep Intermediate shaft that will eliminate your sloppy rag joint $160 without the intermediate shaft not including shipping. |
08-19-2012, 11:36 AM | #2 |
Re: For Sale Rebuilt Manual and Automatic Tilt Steering Columns Jeep intermediate sha
Both are still available!
08-24-2012, 08:48 PM | #3 |
There have been a lot of people interested but no one has came through.
08-28-2012, 12:24 AM | #4 |
ttt
09-06-2012, 11:01 AM | #5 |
ttt
09-09-2012, 10:37 AM | #6 |
Automatic column has been sold
09-20-2012, 11:09 AM | #7 |
No one needs a nice steering column?
09-21-2012, 11:57 AM | #8 |
Performance Shop Owner
What type of jeep is that intermediate shaft from? I never knew they fit or that they were an upgrade for the later model columns.
1980 GMC C25 Sierra Classic with 20,000 ORIGINAL MILES (32,000Km's) & Matching numbers 1977 GMC C35 Sierra Classic Crew Cab 454 A/C with 21,000 Miles & Matching numbers 1980 Chevrolet Silverado K20 400 4spd 4X4 74,000km's 1980 GMC C25 Sierra Classic CREW CAB, All Options, with 49,000 Miles 1979 GMC C15 Sierra Classic 454 1989 GMC R3500 CREW CAB 2003 Grand Prix GTP 1998 Regal GS |
09-21-2012, 03:41 PM | #9 |
It is from a Jeep Cherokee
Posted via Mobile Device |
12-04-2013, 01:16 AM | #10 |
Do you have a Jeep intermediate shaft that will work with the 73-77 splined column?
If so, how much? Thank you. David
12-04-2013, 02:53 PM | #11 |
David, There isn't a Jeep intermediate shaft that will work on the 1973-1977 splined columns. The only option is to actually buy Borgenson joints and make one. Either that or switch to a 78-83 steering column. This is what I had planned on doing on my 77 but came up with an aftermarket shaft that has Borgenson joints
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
12-04-2013, 04:23 PM | #12 |
Do you have the 78-83 Manual tilt column?
Thank you!
12-04-2013, 04:43 PM | #13 |
All that I have built at this time for floor shift is 1973 to 77. It would take a couple days to build the 79-83 floor shift tilt
12-08-2013, 04:55 PM | #14 |
Could I buy the intermediate shaft from you possibly? Need it for my 86
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
