Old 07-29-2012, 11:07 AM   #1
Chevy072
Lokar 16" automatic floor shifter for TH400
This shifter has never been installed. It is a lokar brand 16" automatic floor shifter that bolts on to your TH400 with out modification.$140 shipped
Also available is a TH400 transmission(and torque converter out of a 72 Cheyenne $225 plus the ride.
TH400 crossmember out of a 72 cheyenne big block truck. $55 shipped
Chevy072 is offline   Reply With Quote
Old 07-30-2012, 02:20 PM   #2
Chevy072
Re: Lokar 16" automatic floor shifter for TH400
anyone interested?
Old 08-02-2012, 08:50 AM   #3
Chevy072
ttt
Old 08-05-2012, 04:51 PM   #4
Chevy072
ttt
Old 08-05-2012, 05:58 PM   #5
hopped up
hopped up's Avatar
Would it work for a th350?
hopped up is offline   Reply With Quote
Old 08-05-2012, 06:45 PM   #6
Chevy072
I do believe so. Let me check and get back get back to you.
Old 08-05-2012, 07:14 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that just road grime on the shifter mount?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-05-2012, 07:51 PM   #8
Chevy072
No. it is a couple years of dust from sitting in the back of a 72 suburban project. This has never been installed
Old 08-05-2012, 08:22 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Any idea if this will work with a bench seat? Ill check my fundage
MEMBER #6377
Project "7DEUCE"
Old 08-05-2012, 08:25 PM   #10
kingsolver72
10/30/19
kingsolver72's Avatar
I would like to get in line if it will work on a th350. Definitely interested.
kingsolver72 is offline   Reply With Quote
Old 08-05-2012, 08:34 PM   #11
Chevy072
Sorry,but this is for a TH400 only.
Old 08-05-2012, 08:37 PM   #12
frednoah
86 Scottsdale
Any idea if it would work with a bench seat? I think the height is good, but have no idea where the stick would be positioned in relation to my bench.
frednoah is offline   Reply With Quote
Old 08-05-2012, 08:42 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
Ill get inline on this..
MEMBER #6377
Project "7DEUCE"
Old 08-05-2012, 08:46 PM   #14
frednoah
86 Scottsdale
Did some more reading online. Looks like the positioning is pretty flexible with the adjustments built in. I'll take it if it gets to me.
Old 08-05-2012, 09:11 PM   #15
Chevy072
I think this will work with a bench seat because it is adjustable. The following is from Lokar's website. I will call Lokar in the morning to confirm.
•Positive Lock-Out in Park and Neutral
•Neutral Safety Switch
•Operates with solid adjustable linkage
•Utilizes high quality rod ends
•360 degree lever rotation for extra leg space
•Lever adjustments for dash and seat clearance
•Levers available in 32", 23", 16", 12", 10", 8" and 6" lengths*
•Levers available in chrome-plated or black powder coat finish
•Choice of Original Mushroom, Black Anodized Mushroom, Hi-Tech Lokar or Black Anodized Lokar Knob factory installed with shifters*
•Teflon-lined shifter knob buttons for smooth operation
•Easy to remove shifter knobs for simple boot installation
•Gold iridited main plate and brackets
•All hardware included
•Accessory knobs available separately
•Available for GM, Ford and Chrysler Automatic Transmissions*
•Shifter Boots sold separately
Old 08-05-2012, 09:12 PM   #16
frednoah
86 Scottsdale
Same thing I read. I think it will be fine with a bench.
Old 08-05-2012, 09:15 PM   #17
Chevy072
There are multiple spots on the main plate to mount this,and they make an additional bracket you can purchase seperately that allows you to mount it all the way forward on the main plate
Old 08-05-2012, 09:17 PM   #18
frednoah
86 Scottsdale
I am in if Frenchblue72 passes. He expressed interest first and I don't want to jump him.
Old 08-05-2012, 09:26 PM   #19
Chevy072
Just to clarify. This does not come with the boot,and trim ring as they are sold new without them and i never got one for it.
Old 08-05-2012, 09:35 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
Im in just want to be sure it dont fit th350 as 2 were ahead of me..
MEMBER #6377
Project "7DEUCE"
Old 08-05-2012, 09:49 PM   #21
Chevy072
The model numbers are different for the TH400 and TH350,so i would say for certain it only works on the TH400
Old 08-05-2012, 10:20 PM   #22
hopped up
hopped up's Avatar
No on the th350 I'll pass. Thanks
Old 08-05-2012, 10:53 PM   #23
FRENCHBLUE72
PROJECT 7DEUCE
Ill take it where do I send money?
MEMBER #6377
Project "7DEUCE"
Old 08-05-2012, 11:25 PM   #24
Chevy072
PM on the way
Old 08-06-2012, 07:04 PM   #25
FRENCHBLUE72
PROJECT 7DEUCE
Pay pal sent thanks...
MEMBER #6377
Project "7DEUCE"
