3/5 drop issues
installed the 3/5 drop from cpp, with new drop shocks and panard bar. Problem is it sits uneven now. It all sat even before I dropped it. 1 inch high on the passenger front and an 1 1/2 inches low on driver rear. Anyone else have this problem??
Before and after pic: |
Re: 3/5 drop issues
I had that happen to me it was the spring was not in at the top you might check it..
Re: 3/5 drop issues
I checked it and they seem to be seated right. Do you think if I mixed up the drop shocks it could do that. The only other thing I could think of is pulling the springs out and making sure they were the same. I really don't want to have to do that though!
Posted via Mobile Device |
Re: 3/5 drop issues
Try swapping the springs from side to side and see if that helps.
Good looking truck BTW |
![]() Join Date: Mar 2010
Re: 3/5 drop issues
I had a similar problem with my CPP front springs. I switched them side to side and the problem switched with the springs. After several attempts to find a problem with my installation or my truck I ended up putting a 1 inch rubber spacer under the spring on the low side.
regards BTW nice ride!
65 burb On the road Mar 26th Finally |
Re: 3/5 drop issues
Bought and had installed the same 3/5 drop coils from CPP on my 66', no leaning issues here.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
![]() Join Date: Oct 2010
Re: 3/5 drop issues
I agree with Pops. One of the springs is not seated properly.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
Re: 3/5 drop issues
Had a truck with cut coils once. Ride height changed periodically depending on how I went over the curb into the driveway. It could sit up in the bottom instead of in the correct spot.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
Re: 3/5 drop issues
Yeah, I have the same springs from CPP. No issues here except the front sat to high and I had to cut a coil off the front springs.
Re: 3/5 drop issues
Not to hijack, but Cody how was your ride after you did this, I also wanted a rake but I didn't want to sacrifice my ride so I raised up the rear.
Re: 3/5 drop issues
Well I figured it out but it's still uneven. I put the 2 old rear coils next to each other and one is bent down an inch or inch and a half. So I don't know if my trailing arm is tweaked or the frame or what. I think I'm gonna throw a spacer in to even it out. I would like a little rake but am a little scared to cut the brand new springs!
Re: 3/5 drop issues
here's a couple other pics
#13 |
Re: 3/5 drop issues
Nice!!!!
#14 |
Re: 3/5 drop issues
Well, it sit pretty close to the bump stops. I only have about 10 miles on it since the lowering. The ride is not to bad. Didn't even drive it before I cut the springs so I can't comment on that.
#15 |
Re: 3/5 drop issues
Did you need to c notch the frame ? And it looks great. Any picks of the inside ?
#16 |
Re: 3/5 drop issues
I had the same issue, with the same kit...made a thread http://67-72chevytrucks.com/vboard/s...d.php?t=526332 haven't found a reason for it, coil is seated correctly, nothing bent or damaged ( that I can visually see)
Posted via Mobile Device Posted via Mobile Device |
#17 |
Re: 3/5 drop issues
Mack did u do anything to try and level it out? Zebra I will try and get dome interior pics tonight.
#18 |
Re: 3/5 drop issues
I haven't yet but my next project is spindles/notch. At that time imma take a good look at the springs, great lookin truck btw!
#19 |
Re: 3/5 drop issues
Thanks man it's coming along. I just put a half inch spacer under the low rear spring. Now it sits almost perfect. I am planning on getting spindles too. Then a may put a 1-2 inch block in the back, along with a notch,to get the ride height I want.
