Best fit stock exhaust manifold
Im ready to start purchasing swap items and need to know what stock exhaust manifolds work best in a 70 c20 2wd.
Im using an LS1 from a corvette along with a 2002 4l80e. I have the corvette manifolds, just have not read about anyone using them. Thanks GS 70' C20 CST Posted via Mobile Device |
Has more rust than truck...
Re: Best fit stock exhaust manifold
Trail Blazer SS manifolds are popular, you will need to trim the drivers side trans "wing" a little.
I used the ls6 Corvette manifolds. They worked and fit great. I then swapped to some mid length camaro headers they also fit good. I am now turbo charged so I went back to the stock truck manifold on the driverside.
I built my own mounts so it will be different for each different mount. I had read the corvette manifolds performed as well as headers so I used them. I did a littl trimming on the frame rails but it was minimal. I say use them... Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Good info. Thanks.
I think i will end up building my own motor mounts and try to use the corvette manifolds. Im just concerned with motor mounts and manifolds interfering with my A/C compressor in the stock Vette location. Any thoughts on moving the motor forward or back for tranny or any other clearances. Ill be using a 4l80e. Thanks GS 70' C20 CST. Posted via Mobile Device |
True Addiction
I've got a set off an LS3
RCC |
