Old 07-29-2012, 07:20 PM   #1
diabloceto
A/C questions
So when I bought my truck couple of years ago the previous owner said the A/C worked but they had removed a bunch of bolts and had it unhooked and just sort of hanging there. I finally had the time to replace all the bolts and get it all hooked back up. After turning it back on poof the compressor smoked, seeing as it ain't quite hell but you can see the gates from here hot in Georgia, I really need to get some air going. Since I need a new compressor anyway I was thinking of converting to R134a at the same time. I was wondering does anyone make any kind of kits to do this or what kind of parts would I need to do this? It seems that everything else on the AC but the compressor works too. Thanks for any advice.
diabloceto is offline   Reply With Quote
Old 07-29-2012, 10:15 PM   #2
ole dollor
ole dollor's Avatar
Re: A/C questions
if the compressor is bad , be sure and flush out the system for sure if you take it off and it has black gunk and metal in the lines, i would try and get a sanden compressor to install on your brackets....i really like those compressors and they work great....was the compressor smoking or the fan belt smoking because the compressor was not turning...
ole dollor is offline   Reply With Quote
Old 07-29-2012, 10:48 PM   #3
Rooster's 67
Rooster's 67's Avatar
Re: A/C questions
if converting to R134a there is a kit for converting the STV system to CCOT system. it will also require changing the hoses and all o-rings to R134a compatible materials.
As stated Sanden makes a great compressor and many vendors carry the brackets for converting over, ALL the Harrison A6 compressors are rebuilt (no one makes new as far as I know).
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 07-29-2012, 11:03 PM   #4
diabloceto
Re: A/C questions
The compressor was smoking, the fan belt was smoking and it made a horrible screeching sound. I'll see if I can find one of those to order in the next few days. Thanks.
Old 07-29-2012, 11:16 PM   #5
ole dollor
ole dollor's Avatar
Re: A/C questions
good luck on your a/c conversion , i got mine off e-bay, check to see what is available for your hoses, or what it would take to convert it over to your set up.....to hot to be running around with no a/c....
Old 07-30-2012, 12:49 AM   #6
425HP409
425hp409
425HP409's Avatar
Re: A/C questions
Old Air Products in Ft Worth have everything you need for your truck. Most of the large vendors actually sell their parts. www.oldairproducts.com You will need to flush out the system, replace the drier, install the POA conversion to a cycling system, new expansion valve(insurance), and they have several compressor options. I have used their parts on many cars and trucks with great success. Good People...
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 07-30-2012, 07:17 AM   #7
MARKDTN
Re: A/C questions
Why do you want to convert to R134? I would just go to your local auto parts store and get a compressor, dryer, and expansion valve and put it back R12 after you flush it good.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-30-2012, 08:23 AM   #8
70cst
70cst's Avatar
Re: A/C questions
I am staying with R12 as I have been told this will keep your cab much colder.
I have an AC shop close by that does a lot of work on older cars and trucks.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-30-2012, 01:49 PM   #9
diabloceto
Re: A/C questions
Because I like to do as much work as possible myself and I can't get R12 but I can get R134. I know that R12 can be had but it is going to get more and more rare as time goes on and also more expensive.
Old 07-30-2012, 04:55 PM   #10
MARKDTN
Re: A/C questions
Not really. I almost think it is coming down in price. I bought 2 30# cylinders at Sams for $200 each right when they quit making it. That was a good price at the time. Everyone said I could get $500 each for them in a few years without blinking an eye. Flash forward these 15 years or so. I finally sold 1 of them earlier this year for $250. I really made out like a bandit didn't I? Do what you want, but I will use R12 in vehicles that had it (I have 2 presently) until they die or I run out. R134 is not exacly cheap either. Look on Ebay, look past the crazy ads, R12 seems to actually sell for around $10/lb. The certification is easy to get. It is an open book test that you mail in. It used to cost about $35 for the test. You will almost spend that in R134 conversion fittings.
Also, I would stay away from the Freeze 12 and substitutes. They either contain Butane or have radically different sized molecules so that when the small ones leak out, the big ones are left and the balance is off. R12 (and R134) have molecules that are similar sized. If you have a leak, you just add more, balance is restored. My .02
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 07-30-2012, 05:12 PM   #11
oldspowered67C10
Re: A/C questions
R-12 is the way to go if you can get your hands on some but Ive done a few r-134 conversions and they seem to work fine.
oldspowered67C10 is offline   Reply With Quote
