Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-29-2012, 07:38 PM   #1
richards72chevy
richards72chevy's Avatar
Clutch fan?
My clutch fan sounds real noisey when i take off.Almost like a big rig.Is this a sign that it is going out?I have no over heating issues.
richards72chevy is offline   Reply With Quote
Old 07-30-2012, 11:33 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Clutch fan?
Nope. It's fine. When you idle, temps goes up so the clutch engages. If it does not stop at all speeds or after a few minutes of driving, then you should replace it. Next time it's hot, turn off the motor. Spin the fan by hand. It should spin freely. If you have to force it or it does not spin freely, it's starting to fail.
I ditched the stock fan for a 4.0 Explorer fan. It's lighter and has more fins on it. It's also more efficient. I noticed the difference with the A/C at idle and slow speeds.
Follow my swap here:
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-30-2012, 08:36 PM   #3
richards72chevy
Re: Clutch fan?
Thanks gchemist.The fan does go off after a few minutes.This is the the frst vehicle ive owned that had a clutch fan.Thank for telling me about the ford fan swap.
Old 08-07-2012, 01:04 AM   #4
likaroc13
Rollin' Old Skool
Re: Clutch fan?
interesting...looks like you have a newer engine...i wasn't aware that those have the same clutch fan issues...i know my '93 with 4.3L sounds like an airplane when first taking off, but it smooths out shortly afterward...i assume this Explorer fan would work with my engine as well? how much of a difference did you notice?
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-07-2012, 08:39 AM   #5
gchemist
gchemist's Avatar
Re: Clutch fan?
Read about my conversion here: http://67-72chevytrucks.com/vboard/s...d.php?t=409153
