07-29-2012, 10:21 PM | #1 |
Newb frame swap questions
I'm started on my 51 to S10 frame swap but honestly I'm not sure where to start. I have the cab and bed sitting on the new frame. I'm putting 5.7 with a 700r4 for the drive train.
My cab floor is toast and needs replaced as do the cab corners and where the firewall meets the floor. I'm guessing it would be best to do cab mounts, then cut the floor out, add the motor and tranny then worry about floors and firewall? What do you guys suggest? Posted via Mobile Device |
07-30-2012, 12:26 AM | #2 |
Re: Newb frame swap questions
Repair the cab and then worry about mounting it.
07-30-2012, 09:52 AM | #3 |
I would do the cab first like mr48 said. It would be easier to make the frame fit the cab than the other way around.And if your floor is bad where are you going to measure from?
07-30-2012, 10:06 AM | #4 |
It still has the mount holes which is the only reason I thought maybe do the mounts first. If I do the floor first I suppose I have less room for error. I am unsure if I will need a transmission tunnel yet.
07-31-2012, 05:40 PM | #5 | |
If you are interested, you might take a look at my buiild thread in my sig before you get too far down the road. It might give you an idea of where to start and some of the things to consider before you get started.
My S-10 swap thread: http://www.killbillet.com/showthread.php?t=16296 |
07-31-2012, 07:20 PM | #6 |
62chev is right. There are probably a dozen s10 build threads in the build section. Look at his and others with a note book handy. Write down the basic sequence, note any back tracking. A pattern will emerge for the sequence. It will also give you insight and a list of things you might need to buy or fabricate ahead of time.
I set up an excel spread sheet so I can cut, paste and insert stuff. It has check off boxes next to each task on the left for disassembly, cleaning, fabrication, paint and installation. It has a column on the right for items I need to buy for that assembly. I have it arranged by major subsystems (frame, engine, body, bed, wiring, etc.) I keep a separate critical path sequence list. This method keeps me from going crazy worrying about forgetting something. Also helps when I get bored or overwhelmed with a task, I can find something else on the list to work on. Its basically the same process I use to keep track of all the tasks associated with turning 10,000 pieces of metal, wood and plastic into a building.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-31-2012, 07:33 PM | #7 |
Like others said, do the cab first, then mount it. That's what I'm doing. My cab is done and I don't even have a s10 frame yet...very soon though!
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
07-31-2012, 08:28 PM | #8 | |
