Old 07-30-2012, 10:56 AM   #1
ryanmctee
ryanmctee's Avatar
Front leaf springs too high
Help. I've installed a 2" Tuff Country lift kit on my 72 K10. New springs in the front and blocks in the back. Before and after measurments actually show 4" of lift - much more than I wanted. Anyways, the front of the truck is about 1-1/2" higher than the rear, you can kinda see it in the picture. How can I fix this without raising the rear? I've read about taking a leaf out of the front spring packs. Any thoughts? I've also thought about just buying new stock front leafs....
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 07-30-2012, 11:14 AM   #2
SunSoaked
SunSoaked's Avatar
Re: Front leaf springs too high
That's a GOOD looking truck. It's almost exactly what I'm building, same color and all. If the spring pack is correct (2' lift) and it actually lifted it 4 inches something has to give? Maybe your initial measurements were actually low due to spring sag and it was sitting lower than when it was new.
SunSoaked is offline   Reply With Quote
Old 07-30-2012, 11:21 AM   #3
ryanmctee
ryanmctee's Avatar
I can really buy into that. The truck had the original springs on it. That's why I'm thinking I could buy new STOCK springs and get the front to settle down a bit. But I've been doing some reading and it seems fairly common for guys to remove the bottom spring out of the pack and it does the same thing, just saves a few hundred bucks. Any thoughts?
Old 07-30-2012, 11:42 AM   #4
SunSoaked
SunSoaked's Avatar
How many leaves does the spring pack have?
Another option is to just drop in a big block. The extra weight should even it out
Old 07-30-2012, 11:53 AM   #5
ryanmctee
ryanmctee's Avatar
Three springs in the front packs, but I'm keeping my engine.....
Old 07-30-2012, 01:26 PM   #6
69GWC
My skyjacker 2.5" lift did the same thing, not quite as tall as yours but it has a 2" rake to it now like it needed 4" blocks in the back.
69GWC is offline   Reply With Quote
Old 07-30-2012, 03:52 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Beautiful truck you have there -- the stance is great, I'd leave it just like it is. The front springs will probably settle just a bit with time. My K20 ended up like that after the 2.5" Softrides. I kept my rear AALs and never installed the rear blocks. I actually like the look with the nose up a bit, somewhat like a pre-runner or desert racer look.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-30-2012, 06:44 PM   #8
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Beautiful truck...and I love the stance just the way it is! But it is Your truck...and I dont think you would be happy with stock springs...it doesnt look like you have an excess of tire clearance. Those are 33" arent they? I have a 4" lift on my 71 1/2 ton with 35" KOs and have about the same amount of tire clearance as you do. I would hold off and drive it for awhile and see how you feel about it.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-30-2012, 07:36 PM   #9
ryanmctee
ryanmctee's Avatar
Thanks for the compliments guys. More than likely, I will drive it for awhile and see what happens. IF I really don't like it (which is were I am right now) I will take one leaf out of the front spring packs and try that route.....
Old 07-30-2012, 07:52 PM   #10
Redcap
I'd add a leaf in back rather than take one from the front...
Redcap is offline   Reply With Quote
Old 07-30-2012, 08:20 PM   #11
BLAZERMAN
BLAZERMAN's Avatar
I dont think I would take a leaf out of a 3 spring pack...if I were you I would call Tuff Country and explain whats going on and see what they say.
Old 07-30-2012, 09:20 PM   #12
noco-k5
Just installed a 2 1/2 inch Tuff Country lift on my 70 Blazer. Looks exactly the same. Not sure I like the way it looks, but it definitely rides much better than it did with the original springs which were hammered.
noco-k5 is offline   Reply With Quote
Old 07-30-2012, 10:15 PM   #13
1968vetL-71
Junior Member
1968vetL-71's Avatar
That is a beautiful truck!!! But the stance is horrible. So bad that you should probably just sell me the truck and then I'd just leave it cause it looks killer! Seriously.. it looks fabulous man. Very, very nice.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 07-31-2012, 07:59 AM   #14
Regardless off the measurements,that lift looks appropriate for the tire/wheels. It gives healthy/ample clearance w/o looking any higher than necessary...just right. I prefer the nose up a bit myself. The rear up higher than the front is for 2wds,IMO. This is how 4wds have always sat from back when lifts first came out. They look stout and proud. The front requires more clearance than the rear. You'll find a 4wd that sits slightly higher in the front will ride and handle far better. Just look at off road racers. It tosses the weight to the rear and the rear just follows the front. On crowned 2-lanes your truck won't feel like it's being tossed to the side of the road,like with the rear is raised. It will brake better,too,with more weight transferred to the rear (fronts are way heavier) and nose diving/rear lifting will be compensated more.
Old 07-31-2012, 09:53 AM   #15
ryanmctee
ryanmctee's Avatar
I drove the truck last night and the ride is incredible. Far better than I had expected. Anybody looking for a lift, in my opinion the Tuff Country is the way to go - VERY plush ride for a 40 year old 4x4 truck. Maybe I'm just being anal about the stance. I think I will just drive it for awhile and see what happens. FYI, my 13 year old son now really wants one of these after last night's test drive. That kid had a perma-smile for about five miles.......
Old 07-31-2012, 09:44 PM   #16
That's awesome! Makes it worth every penny,huh? I really like the Tuff Country suspension,too. My '72 GMC is still original with seriously negative arched front springs and beat shocks. One tire is also worn from being on a truck with bad ball joints. I have the Tuff Country stuff,wheels,and tires for it,just need a chance to do it. I love the feel of all that fresh stuff done.
Old 08-01-2012, 11:54 AM   #17
Murphy IRE
Looks good to me and I agree with Special-K and Stocker. I love the two tone. I'm debating that green or staying with the light olive.
Murphy IRE is offline   Reply With Quote
Old 08-01-2012, 11:41 PM   #18
Mudder
Mudder's Avatar
I agree with driving it for a while. The springs may settle in and drop a bit. I have had several of their lifts and I have had good luck with all of them. Truck looks really good.
Mudder is offline   Reply With Quote
Old 08-02-2012, 02:31 AM   #19
MikeS.
MikeS.'s Avatar
That is a great lookin truck.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 08-16-2012, 10:20 AM   #20
ryanmctee
ryanmctee's Avatar
Well, after a full week of driving, I think I'm just going to leave things alone. I don't know if it's me or what, but the front springs have seemed to settle just a bit. Check the picture, the truck almost looks level. Once again, the ride is awesome. Super smoothe for an old 4x4. Thanks for all's opinions!
Old 08-16-2012, 11:11 AM   #21
Redcap
Looks good. Might consider one of these zero rate springs for the rear if you want to level it out all the way.
Old 08-16-2012, 04:23 PM   #22
The wheel openings on these trucks raises more in the front than the rear...maybe to allow for steering clearance. Look at the distance from TDC if the openings and the upper trim. Notice the front is closer. That may be what makes folks think the front is up more than it really is. I think it looks great...still.
Old 08-18-2012, 12:43 PM   #23
msgross
msgross's Avatar
Looks nice... you could always add a 1" zero rate spring in the back... those will also allow you to move the axles forward or backwards to center it in the wheel arch..
ORD and DIY4x.com have them..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-18-2012, 01:03 PM   #24
Dunenutt
Newbee
Dunenutt's Avatar
The stance is perfect!
Mine sat a little high in the front for a while. Hammering it over the rows of speed bumps at Home depot settled it down a bit
Dunenutt is offline   Reply With Quote
Old 08-19-2012, 01:30 AM   #25
JPBrecheisen
special-k is right. The wheel openings are different....even though not by much, but it can make the truck look taller in the front when it actually sits level. I think your truck looks perfect like it sits. Very nice truck.
You can always park it on level ground and put a bubble level on the rocker panel to see how it really sits. Make sure the wheels are straight ahead also, so the caster will jack up the corner of the wheel that is turned outboard.
Thing looks good to me. I kinda like the 4x4's a touch higher in the front anyway.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
