So, I'm wondering if anyone has ever cut down their inner fenders/wheel wells and grinded the edge smooth, to give the smaller look of trailet fenders?
I thought using oem ones would be easier, since there won't be any fittment issues. And would be ideal for me, as I never plan on lowering my truck so no clearance issues with tires. And working on it with them off its been a breeze, but I think they serve a legit purpose. Only issue I'm experiencing is slight rust on engine/bolts from the moisture. (should've primed engine before paint, so that's the price of being impatient) Any advice/experience with cutting them will be appreciated, thanks. Posted via Mobile Device
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Re: Inner fenders idea?
C'mon, guy and girls...no one has any advice?
Gotta support the members and head you in the right direction...
http://67-72chevytrucks.com/vboard/s...d.php?t=528420 They may be a little much for what you are looking for but I'm not sure of your setup.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
I did this many years ago on my chevelle. I raced the car and it made access so much easier. I just used a little 2" air cutting disc. Just use masking tape to tape out the line you want and follow it with the cutting disc. I didnt need to redo the edges, they were fine after the cut.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
78K & 79C Jimmys
i just like them out,sit on the tire
ez to work on the block but back in before the winter tho
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
