Old 07-30-2012, 07:01 PM   #1
87squarebody
87squarebody's Avatar
Ride quality with 5 inch drop up front
Ok i want to lower my 87 swb with a 5 inch drop up front and was planning on using 3inch bell tech spindels and 2 inch springs to keep as much travel as possible.But in the future as I build my project I want to run a wilwood big brake kit with 14 rotors and with that being said I have to use cpp modular spindels which are only 2inche drop and would have to use a 3 inch spring.Will I have a bad ride quality meaning stiff,bouncy or bottoming out on bump stop.Any recommendations for a good set up would be greately appreciated.
87squarebody is offline   Reply With Quote
Old 07-30-2012, 07:15 PM   #2
Jonboy
Slots go on anything!
Re: Ride quality with 5 inch drop up front
I have 3" spindles and a cut factory spring, about 6" total drop in the front. You will need to play with the bump stops a bit, but it rides well. Looks good, too. My advice would be to get the modular spindles now, if that is the way you will ultimately be going. You can always upgrade the brakes later.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-30-2012, 08:24 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
I have 3 inch drop springs and 3 inch spindles. I almost think the front of my truck isnt stiff enough. But I have mine built to handle and any stiffnes or bouncyness comes from bad shocks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-30-2012, 09:28 PM   #4
87squarebody
Yes im thinking about getting the modular spindels and up grade the brakes later but using a 2 inch drop spindle and a 3 inch drop spring will limit the travel due to a shorter spring.
Old 07-30-2012, 10:54 PM   #5
ghettoluxury
ghettoluxury's Avatar
I don't know your fab skills, but have you thought about sectioning the crossmember? You can go up to 1.5" with out any problems and gain some ground clearance in the process.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-31-2012, 12:32 AM   #6
Square_78
Square_78's Avatar
Mine is dropped 5.5 in the front with cut coils. It will bottom out on the bump stop mounts (rubber removed) just before the a-arms hit the ground. Took a bit of work to get it aligned but its fine now. The ride is the same as it was stock. I wish it was a little stiffer now that its so low. I might change to some 3/4 ton coils and chop them to the same height. That might stiffen it up a little bit. Rides like a cadillac right now, but I prefer the sports car feel.
Square_78 is offline   Reply With Quote
Old 07-31-2012, 12:34 AM   #7
INSIDIOUS '86
Same here^
But my bumpstops are the pavement thats my bumpstop
Old 07-31-2012, 02:22 AM   #8
muthstryker
muthstryker's Avatar
Originally Posted by INSIDIOUS '86 View Post
Same here^
Yep!!!
I want to cut the factory bump stop mount off my a-arms and weld up a new steering stop. My truck drops like an inch and it smacks the bump stop mount. It would be perfect if I didnt make any contact at all.
Matt
muthstryker is offline   Reply With Quote
