07-30-2012, 10:18 PM | #1 |
87 close to original valve cover paint?
Pulled my valve covers bead blasted them then primed them with duplicolor engine enamel primer then coated it duplicolor semi gloss black says for "FORD" and is 1635 item number from duplicolor.
they look pretty good but they're a bit too shinny really is there anything out there thats closer to the original sheen that you guys know of? duplicolor does has 1634 low gloss black that says GM but I bought that too and tested a spot before I painted them and it seemed way to flat.... any tips? thanks |
07-30-2012, 10:29 PM | #2 | |
Re: 87 close to original valve cover paint?
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
07-31-2012, 01:11 AM | #3 |
Use a clear coat over one of the two to protect and get the sheen you want
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-31-2012, 05:19 PM | #4 |
thanks guys,
I noticed you can buy "GM chassis restoration paint" online anyone familiar with a spray can paint that is supposed to be what they put on underhood trim for gm? looking but all I keep seeing is GM chassis paint. |
08-01-2012, 11:22 AM | #5 |
ttt
