Old 07-31-2012, 12:07 AM   #1
poppy510
Cab Lights
Ok...I have studied the " pictures wanted of clearance/roof lights" thread and the "Tow Truck/Rollback/Hauler Pics" thread and I have not found a definitive answer on which trucks came with cab lights. Based on the photos, they were clearly not required for tow/haulers, 30's, etc. Were these an option, part of the CST package, or what?
Mine is a 69 CST-20. My grandfather bought this truck new, and growing up I was always told that when a fleet of 50 or more was purchased, one was provided with lights. Sounds like an urban legend. I am assuming these are the "marker lamps" listed on the build sheet.
Can anyone explain?
poppy510 is offline   Reply With Quote
Old 07-31-2012, 12:21 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Cab Lights
Pretty sure all 1-tons came with them, but they were optional on all others.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-31-2012, 09:05 AM   #3
Re: Cab Lights
ICC started requiring clearance lamps on 10,000# trucks starting in '69. All '69 and newer dual rear C/30s came with clearance lamps. They were an option on all other trucks,even 67/68 C/30s. The first year '69 cab light lenses were unique. They were flat and looked like hockey pucks. From '70 till the last R/V series in '91 the lenses were what they call fireman's hat style. The pre-69 lamps where teardrop shaped Chrome metal with plastic lenses. This style was a universal style with most trucks of most brands.
Old 07-31-2012, 11:00 PM   #4
poppy510
Re: Cab Lights
great info Tim.
You stated "All '69 and newer dual rear C/30s came with clearance lamps. They were an option on all other trucks,even 67/68 C/30s."
Mine is a 69 CST20, not a 67/68 C/30.
Were the lamps simply an option for '69 3/4 tons?
Old 08-01-2012, 07:47 AM   #5
Re: Cab Lights
Yes. Is there a SPID on the glovebox door? I'm not sure how much the option was,but probably not much at all. Figure with that option you got way more than 5 simple lights and wire. It requires an entire roof skin with special mounting pads.
Old 08-01-2012, 10:58 AM   #6
poppy510
Re: Cab Lights
40 year old mystery solved. Case closed.
