Old 07-31-2012, 01:03 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Question 4wd vs 2wd steering box
Want this but it says 4wd applications. Didn't 4wd trucks just have different pitman arms? I don't see why agr would make a 12 ratio for 4wd vehicles and not 2wd
http://m.summitracing.com/parts/agr-244451
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-31-2012, 02:15 PM   #2
68burb
Re: 4wd vs 2wd steering box
how the arms mount are different too. 2wd have the nut in the middle clamping the arm down. 4wd have a bolt through the side of the pitman arm. you could open it up and swap the shalfs, but if you spend that much I wouldn't want to crack it open,lol
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 07-31-2012, 03:54 PM   #3
wilkin250r
wilkin250r's Avatar
Doesn't the 2WD steering cross over and connect to the passenger side wheel? while the 4wd version connects to the driver-side wheel. I have a 4WD, but I know that the aftermarket crossover steering kits require you to swap to a 2WD steering box because of the way the pitman arm mounts.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 07-31-2012, 05:29 PM   #4
INSIDIOUS '86
I'm just looking to add this to my 2wd truck
Old 07-31-2012, 07:33 PM   #5
WarBeard
WarBeard's Avatar
4wd box the Pittman arm can only go on one way. 2wd box has a nut on the end of the shaft to lock the arm on as the arm is tapered. Im pretty sure the 2wd arm can be clocked.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-31-2012, 11:19 PM   #6
grayharville
^^who I am^^ what I say>
grayharville's Avatar
I've taken all the guts from a cracked 4wd box and put them in a 2wd box, just my .02
Just thought of something, if that's a quick ratio box the gears in it are likely different and stock parts probably wouldn't work.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 08-01-2012, 01:36 AM   #7
INSIDIOUS '86
I'm going to call agr tomarow and get to the bottom of this
