07-31-2012, 04:49 PM | #1 |
Metal Door Panels
Anyone buy those matal door panels i see everywhere? Is the fit good, are they really just prime and paint? Can we see some pics?
I need door panels, my original vinyl ones are getting pretty worn.
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
07-31-2012, 08:15 PM | #2 |
Re: Metal Door Panels
I picked up a set for my 72 GMC they I don't think are correct to the year but will look nice and should be very hard to wear out.
07-31-2012, 08:39 PM | #3 |
i installed them on my 69.i think they look nice.
07-31-2012, 10:02 PM | #4 |
I am considering them, my interior calls for off white... thats an easy color to find anywhere..
08-07-2012, 09:09 PM | #5 |
On the metal door panels, are you using the escutchens under the window or door handles? Do they install easy?
08-07-2012, 10:20 PM | #6 |
They are not exactly "off white". GM used the name sandalwood in this case Ditzer number 23373 matches the door panels or seat back panels. If you are going to paint door panels I'd use the stock style. Here are two trucks a 70 cst with 624 trim code and a 70 gmc with 625 trim code. Door panels and vinyl trim are the same color as your truck. In fact everything but the seat insert and the gmc glove box door are a match.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-08-2012, 07:58 AM | #7 |
One of the main reason i am considering the metal panels isnt cause they are cheaper, its because i feel that every few years or so i can remove them and repaint them making it look fresh again. You can see in the pic you posted how dirty the vinyl gets and even keeping up with the cleaning, it does grind in...
My window cranks are original but have chrome knobs and when ordering new, the only choice was black or clear.. Thank You for posting those pictures.
08-08-2012, 09:43 AM | #8 | |
When you paint yours are you just ruffing it up with sand paper? Mine need to be cleaned up and have some light rust spots. Not sure what to do with the trim too. Either the chrome is worn off or it was just steel. |
08-08-2012, 09:53 AM | #9 |
Did you buy them new and they came that way? I did plan on a full sand, prime, sand, prep. paint.. They repro that trim piece above the door panel..
08-08-2012, 11:54 AM | #10 |
On my truck when I got her. I removed them when working on my locks and replacing some internal door parts. Still have them off and don't know if I should replace them or repaint them. Pretty sure they are original. Was going to test by taking some 220 on my sander and going over it, then mousing out the details, prime, paint and then see if I still want them.
08-08-2012, 03:01 PM | #11 | |
As I forgot to notate the color chart earlier here it is.
08-08-2012, 03:38 PM | #12 |
I am a Referee of life.
I sanded and painted mine.While I had them off I took some very thin styrofoam packing sheets(like nesprint but out of styro) and spray glued i to the backs.It quietened it down and helped some wth heat.The factory used a clear plastic sheet to help seal out air,I used a thin rubberized cloth gasket material.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
