Old 07-31-2012, 06:18 PM   #1
1972 CST
Brakes need help
When I bought my 85 shortbed it came with the 1 inch wide rotors and small brakes in the back I just switched to 1 1/4 rotors and bigger brakes in the rear I was wondering if I need to switch my master cylinder?
1972 CST is offline   Reply With Quote
Old 07-31-2012, 06:53 PM   #2
spencer_41188
spencer_41188's Avatar
Re: Brakes need help
you will notice the brake peddel will travle farther then befor but as long as it dont hit the floor and you still need pressure ie wont stop and the peddel has hit the floor
get some floor/firewall to peddel mesurements, with engine off have a friend crack a bleeder to releave pressure so the peddel will bottom out mesure between peddel and floor/firewall then close the bleeder and with the engine on (to make the booster work) have your friend mesure the peddel with all your effort pushing on it ... i would get a bigger bore master if its less then a 2" or 3" diffrence but thats your call how far do you wana push the peddel that stopes you?
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 07-31-2012, 06:58 PM   #3
1972 CST
I got two master cylinders from the part stor one has a big Piston and one has a small one my truck already had a big bore in it so should I put the bigger one back in ?
Old 08-01-2012, 04:35 PM   #4
spencer_41188
with the small bore you will have a longer stroke but more pressure peddel is easyer to push
with the big bore you will have a shorter stroke and less pressure and the peddel is harder to push
if you are NOT running a booster the small bore is the better choice
and if you really wont a touchy peddel go with the small bore
all depends on what your doing with the truck and how you wont it to feel
to me touchy peddles remind me of a ford ... cant stand it and never get use to it
both will work but its your call
