Old 07-31-2012, 09:29 PM   #1
Midgets50
Midgets50's Avatar
angles for firewall
does anyone happen to know the angles of the metal that goes from firewall to the angled foot area then the angle from the foot area to floor pan? im having a guy bend sheet metal for my firewall and floor pan and he needs to know what angles to bend
thanks in advance
Midgets50 is offline   Reply With Quote
Old 07-31-2012, 11:08 PM   #2
mknittle
mknittle's Avatar
Re: angles for firewall
I get 50 degrees at the toeboard to floor on mine but I will check some of the trucks in waiting in the morning.It seems that every one of these trucks are a little different.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-31-2012, 11:47 PM   #3
Midgets50
Midgets50's Avatar
Thanks i might just see if he can come out and do the measurements at my shop just to be sure everything is at where it is suppose to be
Old 08-01-2012, 09:27 AM   #4
mknittle
mknittle's Avatar
That would be a good idea.I is allways good to see somthing that you are building.
i would have him make it a little big so you can trim to fit.
Mark
My GMC build.
Old 08-01-2012, 11:40 AM   #5
Midgets50
Midgets50's Avatar
im using about a 5x10 chunk of sheet metal and im gonna have him bend it so that i can have firewall, floor pan all in one chunk so all i have to do is weld the solid piece. makes less welding and itll look smoother imo
Old 08-01-2012, 07:13 PM   #6
mknittle
mknittle's Avatar
Should look clean. let me know if I can help with Measuerments we have a few of AD trucks
Mark
My GMC build.
Old 08-02-2012, 11:10 AM   #7
Midgets50
Midgets50's Avatar
would you be able to give any advice for how to do cab mounts to the floor pan if im completely replacing everything. ive got the mounts from the frame up made just dont know how to do the connecting to cab part now
Old 08-02-2012, 10:06 PM   #8
mknittle
mknittle's Avatar
i made mine out of some 12ga I had they went together easier than I thought.i have a couple pics here
http://67-72chevytrucks.com/vboard/s...486137&page=43
almost the bottom ot the page.I think I have more and some stock dementions. I will gather them up and post what I have Later when my wife gets done with the computer. I just made mine last week so memory should be good.
Mark
My GMC build.
Old 08-02-2012, 11:01 PM   #9
mknittle
mknittle's Avatar
I am going to get this kit and use the parts that I need. The shackle bushings and the pads.
http://www.lmctruck.com/features/ca/CA9B1.htm
Mark
My GMC build.
Old 08-02-2012, 11:10 PM   #10
mknittle
mknittle's Avatar
this helped me. mr48chevy was kind enough to post these for me. theseare the stock front cab mounts
Mark
My GMC build.
