Old 07-31-2012, 09:59 PM   #1
Denee007
Denee007's Avatar
Steering column install advice, steering wheels
Hi, I put my ididit column in today (temporarily)and I was kind of excited until I put my seat in. Looks too close to my legs. This is a tilt column. I was thinking to move the column drop towards the seat which hopefully would elevate the column and then pull column the remaining inch it has sticking out in the engine compartment. I cannot pull the column towards the seat now because where the wiring comes out of the column won't allow.
Next is where do I buy a steering wheel? I didnt discuss this with Justin at Scott's hotrods. I really need a steering wheel!
Examples of steering wheels would be nice. ; )
Denee007 is offline   Reply With Quote
Old 07-31-2012, 10:06 PM   #2
seanery
seanery's Avatar
Re: Steering column install advice, steering wheels
It seems if you had a different column drop bracket you could raise it an inch at the bracket - might give you an extra 2-2 1/2 inches height at the wheel.
seanery is offline   Reply With Quote
Old 07-31-2012, 10:18 PM   #3
Denee007
Denee007's Avatar
My husband said see about getting another column drop, I was thinking I could MAKE this work with what I have. I'll call Scottshotrods tomorrow and see about another drop.
Thank you!
Old 07-31-2012, 10:20 PM   #4
solidaxel
solidaxel's Avatar
Take a look at the early Corvette, Camaro wheels, and 6 bolt hubs.
Looks like you could use a shorter column drop!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-31-2012, 10:55 PM   #5
Chevette
Chevette's Avatar
Have you thought about the possibility of dropping your seat a couple of inches? If you can do it, you'd likely gain a lot of room.
Chevette is offline   Reply With Quote
Old 07-31-2012, 11:04 PM   #6
mknittle
mknittle's Avatar
i agree about the drop.
solidaxle that is one nice looking truck.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-31-2012, 11:25 PM   #7
Denee007
Denee007's Avatar
Gosh Solidaxle, your truck is gorgeous! I'll check into some of the wheels you suggested.
As for lowering the seat Chevette, too much work! Lol
Tomorrow I think I'll unbolt the existing drop, and just hold it to where I'd think it should be, then order another drop. Should be simple enough to figure out. I'd still like a steering wheel mounted, tomorrow I'll start a thread asking to see steering wheels, nothing fancy, but nice .
Old 07-31-2012, 11:36 PM   #8
solidaxel
solidaxel's Avatar
Thank folks for the kind words, the speedo just turned over 50,000 miles!!
LS 3 4L70E
