Old 07-31-2012, 11:00 PM   #1
SS From the "Wood"
SS From the "Wood"'s Avatar
frame specs
I am close to putting full air ride suspension on my '84 CCSB, but before I do, I would like to make certain that my frame is square. What would be the best method to do this?
'84CCSB "Black Betty"
God is GREAT all of the time!
SS From the "Wood" is offline   Reply With Quote
Old 08-01-2012, 11:13 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: frame specs
My data pages do not go back far enough, but here is a photo of the 88up ladder frame under a truck for reference. You have "holes" on each side on the bottom in different locations. As marked in the photo, measure from A on the left to E on the right (cross ways), then measure from A on the right to E on the left, it should be the same. Do the same thing in the back finding reference points that equal on each side. As long as it "cross measures" you should be square. We use a tram gauge to do this with, but a tape measure and two people can get the same results with some effort. Second image is of a tram gauge.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-01-2012, 11:54 AM   #3
slammed427
slammed427's Avatar
Re: frame specs
Here is for an 84 3/4ton 2wd. Your wheelbase is approx 20" longer than this.
http://www.73-87chevytrucks.com/tech...assis_dim5.jpg
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 08-01-2012, 12:31 PM   #4
SS From the "Wood"
Re: frame specs
perfect. thx!
