Old 08-01-2012, 02:35 AM   #1
The Gibster
The Gibster's Avatar
Help With 1972 K-5 W/ 63" Rear Springs
I just purchased a 72 Jimmy a month or so ago and I need help figuring out the rear suspension situation. Right now it has 63"s in the rear with a shackle flip and 6" shackles. I am 98% sure the PO removed a leaf or two to make it softer.
I am planning on using it as a weekend rig that I can drive to and from the trail/desert with and right now I feel it is way too "bouncy" to be street worthy. I want to keep the 63's so my question is there anything I can do to stiffen it up? Right now I was thinking of adding a leaf or two to the pack and a zero rate to move the axle back. Any suggestions?
Thanks everybody
"You may be a redneck if... you have spent more on your pickup truck than on your education."
The Gibster is offline   Reply With Quote
Old 08-01-2012, 10:30 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Help With 1972 K-5 W/ 63" Rear Springs
I did a 64" spring conversion on my blazer. Mabey some better/multiple shocks would help. Here's the thread http://67-72chevytrucks.com/vboard/s...d.php?t=480181
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-01-2012, 11:07 AM   #3
The Gibster
I read your thread a while ago which gave me hope! I am just curious, can you stand at the back of your blazer and push up and down on the tailgate enough to make it feel like it is bouncing off the ground? I can do that with mine, I don't actually get it off the ground but I figure it would give you an idea of where I am at. I just don't feel like that would be safe going down the highway.
What is your Blazers on road characteristics with the longer springs?
Old 08-01-2012, 11:51 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Cant help ya with the on road behavior. It looks like this--->http://67-72chevytrucks.com/vboard/s...ighlight=miler
GM put these springs stock on the back of Chevy trucks. If its good enough for them, its good enough for me.
The longer shackle might give a little more lateral instability in corners though.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
