I cant make up my mind. Need your opinion.
So im at the point where i will be putting a new V8 in the truck and i have reached a dilemma. Either carb or EFI. Kidding of course im going EFI but this is the real predicament: Ls swap or splurge and go for the crate RAMJET 350. One of the main things im hoping for with this swap is Fuel Efficiency. With the LS swap im going to need a variety of things: engine, harness, fuel, motor mounts and transmission adapter. I have a 6000 budget and i really would like to stay in that range. I can get the entire RAMJET 350 with a serpentine system for 6K. Brand New, Never opened, ready to go. So heres some info about the truck. 1986 K1500 with SM465 and 3.42 gears. I would love to swap the transmission and gears but I made the decision to spend money to rebuild the SM465 and put a 600 posi-trac unit in the back. So i cant swap gears or tranny out. So this is where im at.. Which is easier? which is better? LS 6.0L or 5.7L RAMJET 350??
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
Re: I cant make up my mind. Need your opinion.
If it was me id go the lq4 throw the carb intake on it and get a msd ignition they make one for the coil packs http://www.msdignition.com/product.a...893&terms=6010 Its cheaper but your running a carb vs efi tho.
Why bother swapping a carb onto the lq4? It's one of the best candidates for a swap. Its cheap, easy to find, and you can swap out a ton of parts from engines like the lq9, l92, and even the ls2 and 3 depending on the part. It's what I plan to do once I get a bit more money...
For fuel efficiency in general the ls engine will definitely be better simply because of its newer more efficient design. However if you want the most fuel efficiency I'd consider getting one of the newer engines that has VVT or DoD. They probably won't handle as much power, but definitely better on gas.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Not too up on this, but seems to me they should make a bellhousing that will connect the 465 to an LS without an adaptor. LS seems to be the power plant to have so why do it twice, if need be run the carb and MSD set up for now and collect the computer stuff for future mods.
Slots go on anything!
I'd say LS swap as well. if you do some research, you will probably stay well under your goal od $6K.
1974 Jimmy- 5.3/4L80e/NP241 |
Also, these are fairly expensive but since the SM465 is not the best tranny for gas saving you could try to find a gear vendors overdrive unit for it
Happy to be here
![]() Join Date: Mar 2000
I would go with the LSx swap for your application. I love my Ramjet 350, but it has limited tuning abilities. With the LSx swap, the skies the limit. Since you don't want to change gears, the LS motor will allow you to build and tune more torque than the Ramjet has.
![]() Join Date: Oct 2011
Stay away from VVT or DOD (variable valve timing / displacement on demand) unless you want exploded lifters, flattened cam lobes and broken valve springs. Too many times I've seen the cam phaser on a VVT motor stick and wipe out a couple valves, etc and too many times I've seen lifters on DOD motors blow apart and worn cam lobes with low mileage..
I'd go with whichever you think you will be most happy with. LS motors are great and so are the 'ol smallblocks, just all depends on what you plan to do with it. The LS motor may be a better bet considering you have a 1 to 1 final drive and the LS reves a little higher, not that 3:42's rev all that high.... If it was me? 350 with a Quadrajet or TBI but that shows you were I come from....LOL I think you've already made your mind up on the Ramjet. I would just see if you can get a better price. Shop around a bit, it can be had for less. Last edited by beamn7; 08-01-2012 at 12:28 PM. |
Those ls motors have a wonderfully torque band. Jeremy clarkson put a z06 vette in fith and rolled from a stop to 160mph. There is nothing wrong with a carb. Anybody that knows how to make a carb tune decent can make it do the same thing. Except idle when cold cause a computer does that for you. Hot rod mag did a test with an Lsx engine carb vs efi and the carb came out on top with more power which means efficiancy. Of coarse they tuned with a wide band o2 sensor
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I was actually just discussing the vvt, (DoD, AFM, whatever you want to call it), thing the other day with my uncle. He is a mechanic by trade, so not a total nobody, but he said that the majority of the cars that come in with vvt related problems are from the earlier models of the engines and that the second generation AFM's were set up much better electronically and he hasn't had any come in for those types of problems. I personally wouldn't buy one, simply because it really is just one more thing to go wrong, but I thought I'd play devil's advocate because I don't think they're all that bad anymore
I forgot about the DoD isn't there a way to remove it from the engine or turn it off?The reason i said run a carb its easier and cheaper up front the down side to one is cold starts and a few less mpg.
#12 | |
#13 | |
#14 |
I didnt realize how cheap an LSx swap would be. Wiring harness from GMPP is $800. I can get the motor for $1000 from my friend (serpentine system included). The tanny adapter is probably $800 im assuming?? Get a holley fuel regulator and holley external fuel pump for $50 and $150 respectively. But what about the clutch and flywheel i cant find any info on them...
#15 | |
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
#16 |
heres a little trick to save money when buying from jegs they have a price match garentee .... use it!!! find what you wont on jegs go to google shopping search manufacture and part number arrange list by price from low to hi. you could save a fue hundred.
i saved $300 on my fast ez efi doing this and didnt buy from jegs but got a good deal by looking saved $400 didnt pay a core on my transmission with edelbrock in most cases you will get a better deal at an engine machine/building shop they get the sweet deals
#17 | |
#18 |
I definitely appreciate that, when I start buying my parts this will come in handy!
#19 | |
Hope this helps. |
#20 | |
#21 |
but technicially any type of block could be a 383 if you bore it to those dimensions.
#22 | |
#23 | |
a little the truck came with tbi and when i put the 383 in i took all that out and ran carb for a wile dual quads to be exzact lol got them dialed in and got bord with it so i set out to find 1000 cfm 1 stock tbi only flows 500 cfm and fast flows 1000cfm enough to suport 600hp ... more power 2 i dont have to adjust anything anymore and i dont have to worry about trips threw the moutains 3dont have to let it worm up just turn the key and go, dont have to worry about mpg's going to crap over a dirty filter the only bad thing is this has nothing to do with timeing so you may get knocking witch means you got to change the weights, springs, or adgust vacume on your dizzy other then that its sweet
