removing leafs from springs
been reading a lot about removing some leafs from the springs, has anyone done this and what does it do for the ride, handling and height. i am using all the stock springs but running front disc conversion and 10 bolt posi rear with disc. good or bad idea and if good what springs are removed.
Re: removing leafs from springs
The top photo is my 48 with leaves removed with 205-60-14 tires on 7 inch rims.
The second photo is the front spring under the 48 and a good indication of what will happen when you remove leaves from the spring. Plus it never did drive all that great with this setup although I put around 100,000 miles on it with the setup. |
that shows me a lot thanks for the pics. i think i will stay with all the springs and go with a dropped i beam. thanks again
That was a quick and nasty fix when I was putting the truck back together in Aug 1989 with the intent of driving it to one car show and pulling it back apart. Before I started working on it I rolled my daily driver pickup and totaled it and had to drive the 48 to work daily.
