08-01-2012, 03:02 PM | #1 |
is very serious
spindle help asap
will 90s chevy 2wd spindles work with a 67 chevy? i mean like lining up properly with balljoints and tie rods... i know 71 through 87 trucks will but havent heard anything and cant find anything about 88 and up.
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold 1969 C-10 2wd fleetside LB 327 3spd - sold 1969 C-10 2wd fleetside LB 350 th350 - sold 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
08-01-2012, 06:01 PM | #2 |
Re: spindle help asap
I haven't ever tried but I doubt it. Someone would have already done it w/these trucks being around for as long as they been.
08-01-2012, 06:44 PM | #3 |
67-72 parts collector,…
There are some members using the light duty 3/4 ton 88-98 stuff to put 6-lug disc brakes on the 67-87 trucks.
This requires you to run a 3/4-ton (67-87) lower a-arm (larger balljoint hole),... 88-98 upper and lower ball joints,... and 88-98 outer tie rods. I'm not a proponent of ths swap because the spindle geometry has to be different. Some members have done it with success. But I remember one member spending over $600 in parts to make this swap happen. This info is also used to run 88-98 2wd LIFT spindles,... on the 67-87 trucks. What is the reason you want to use the '90's spindle? What is the condition of the front end of your truck? Adding drop spindles? 5-lug? 6-lug? What else can you tell us.
